Results 1 to 5 of 5
    Reputation: fda47's Avatar
    Fox 32 F120RL, play when fully extended
    I really don't know how to word what I observed but here goes.
    Had my Trance X2 for a year now and so far there have been no problems. Recently though, twice exactly, the fork hesitated for a little bit before compressing when I hit a bump or dipping.
    So after the rides, I looked at the fork, compressed it by pushing down on the bars and it works fine. This is what I noticed weird though. Fully extended and keeping the front tire still, I pull up on the fork and I notice a 2mm up/down play, meaning I can move it by 2mm without any resistance at all.
    Thinking it might be normal, did the same thing on my son's X3 with a F120R and it does not have that play.
    Is this a sign that the seals or whatever, inside the fork is going bad? Want to address it now while it's not worse yet.
    2009 Giant Trance X3
    2010 Giant Trance X2
    From my limited experience, the "2mm up/down play" is normal.
    An air sprung Manitou fork I have developed ~5mm of play and my LBS sent it in to Manitou. We were told this is normal. I didn't like that answer, so I had the LBS take it apart. They found (and discussed it with Manitou) that the topout spring (as best as I can remember) was compressed slightly shorter then spec'ed causing this effect.
    The Fox F-120 RLC that I replaced the Manitou with has developed ~2mm of the same up/down play and I assume it is the same thing going on with either the "topout spring" or "air negative spring", both of which are on the air spring shaft.
    I would look elsewhere for the cause of the hesitation.
    Thanks gmcttr.
    Guess I shouldn't worry about that play for now. Only reason I asked about it is coz my son's fork doesn't do the same.
    The fork being stuck, I may somehow be like stiction but needed much force to get the fork to move.
    When is the last time the fork was serviced?
    I bought the bikes last summer and has not been serviced yet. It was checked by the LBS last April though.
  1. 2010 Fit Fox 32 F120RL stiction?
    By ilostmypassword in forum Shocks and Suspension
    Last Post: 04-24-2010, 04:03 PM
  2. Manitou Swinger fully-extended, even with no air pressure
    By Luke555 in forum Shocks and Suspension
    Last Post: 09-09-2009, 06:29 AM
  3. Stumpy travel mod on F120RL
    By larlev in forum Specialized
    Last Post: 06-27-2009, 09:44 AM
  4. Fox F120RL on 08 stumpy comp
    By larlev in forum Shocks and Suspension
    Last Post: 05-01-2009, 08:06 PM
  5. starting pressure for F120RL?
    By damion in forum Shocks and Suspension
    Last Post: 08-27-2008, 03:32 PM
