Busted!!!
Forks: Complete Axle to Crown Lengths Library
I spent some time talking with different manufacturers about Axle to Crown Lengths. Unfortunately they dont all follow a standard, so changing from Brand A to Brand B of the same travel, can have more effect on handling than just the dampening characteristics. You could have as much as 1/2 degree variation in head tube angle using different brands with the same travel. FOR ESTIMATING PURPOSES ONLY: Typically you can estimate a 0.5 degree (1/2 degree) change in Headtube Angle for every 10mm of Axle to Crown Length changed.
Below is a list of Manufacturers Specified Axle to Crown Lengths. It would be great if anyone would measure their fork and list the length so it can be added in parenthesis so we can see what the margin of variance actually is. The next post gives directions on how to measure Axle to Crown Length on your fork.
Please Copy and Paste the following information into your reply and fill it out completely.
Manufacturer:
Model Year:
Model:
Travel:
Axle to Crown Length:
Custom Work: (PUSH Industries, Garage Works, Hippie Tech, etc.)
THIS IS NOT A COMPLETE LIST, I WILL BE ADDING TO IT FOR THE NEXT COUPLE DAYS. 29er forks and listings from DT swiss, White Bros and Maverick coming.
[SIZE="3"]FOX[/SIZE] Fox Racing Shox Website
Current Model Year Unless Noted Otherwise
All models +/- 5mm
32mm Forks
F80: 450.9mm
F90: 460.9mm
F100: 470.9mm
F120: 490.9mm
Float, Talas, Van 130: 500.9mm
Float, Talas, Van 140: 510.9mm (08 Talas: 515mm)
Talas 150: 520.9mm
36mm Forks
Float, Talas, Van 160: 545.3mm
40mm Forks
Fox 40 180: 545.8mm
Fox 40 203: 571.2mm
[SIZE="3"]ROCKSHOX[/SIZE] RockShox website Axle to Crown Chart
All models +/- 5mm
28mm Forks
99-08 SID 63: 434mm
99-08 SID 80: 451mm
32mm Forks
Argyle 80: 471mm
Argyle 100: 491mm
SID 80: 453mm
SID 90: 463
SID 100: 473
Dart 80: 454mm
Dart 100: 471mm
Dart 120: 501mm
Tora XC/SL/RACE 80: 450mm
Tora XC/SL/RACE 100: 470mm
Tora AM 80: 459mm
Tora AM 100: 479mm
Tora AM 120: 499mm
Tora AM 130: 509mm
Recon XC/SL/RACE 80: 451mm
Recon XC/SL/RACE 100: 471mm
Recon AM 80: 459mm
Recon AM 100: 479mm
Recon AM 120: 499mm
Recon AM 130: 509mm
05-08 Reba 85: 458mm
05-08 Reba 100: 473mm
05-08 Reba 115: 488mm
Reba 80: 453mm
Reba 100: 473mm
Reba 120: 493mm
06-08 Revelation 100: 478mm
06-08 Revelation 115: 493mm
06-08 Revelation 130: 508mm
Revelation 140: 521mm
Revelation 140 w/Maxle Lite: 518
Pike 95: 473mm
Pike 140: 518mm
Boxxer Ride 130: 494mm
Boxxer & Ride 174: 544mm
Boxxer 200: 568mm
35mm Forks
Domain 115: 500mm
Domain 160: 545mm
Domain 180: 565mm
Lyrik 115: 500mm
Lyrik 160: 545mm
40mm Forks
Totem 135: 530mm
Totem 180: 565mm
[SIZE="3"]MAGURA[/SIZE] Magura Website
All models +/- 5mm
32mm Forks
Odur 85: 458mm
Odur 100: 473mm
Menja 85: 458mm
Menja 100: 473mm
Menja 130: 498mm
Durin 80: 453mm +/-3mm
Durin 100: 473mm +/-3mm
Durin 120: 493mm +/-3mm
Thor 140: 520mm
36mm Forks
Wotan 160: 540mm
[SIZE="3"]MANITOU[/SIZE] Manitou website
All models +/- 5mm
32mm Forks
R7 80: 456mm
R7 100: 476mm
Minute 100: 478mm
Minute 120: 498mm
Minute 130: 508mm
Minute 140: 515mm
Nixon 145: 518mm
Nixon 160: 540mm
Gold Label 80: 460mm
Gold Label 100: 480mm
34mm Forks
Travis Single 180: 572mm
TravisTriple 180: 562mm
TravisTriple 203: 585mm
[SIZE="3"]MARZOCCHI[/SIZE] Marzocchi website Axle to Crown Chart
All models +/- 5mm
28mm Forks
TXC 60: 466mm
32mm Forks
22 100: 479mm
22 120: 499mm
33 80: 447mm
33 100: 467mm
33 120: 487mm
44 120: 487mm
44 140: 507mm
4x 100: 490mm
Corsa 100: 467mm
DJ 100: 490mm
35mm Forks
55 160: 541mm
55 ATA Micro 165: 546mm
38mm Forks
66 180: 564mm
888 200: 567mm
[SIZE="3"]Maverick[/SIZE] Maverick Forks
32mm Forks
SC32: 495mm
DUC32: 520mm
Busted!!!
look on the sram website on the manufacturer section and you'll have all the RS ones
Busted!!!
Yeah but the Sram site is way out dated for the most part. That is one of the problems I found. Ive got most of the current ones, just got a bit to get done before I can get back to filling in the blanks.
Edit: I just saw at the very bottom of the list is the full chart of just A2C lengths. RockShox A2c Chart
Thank you so much mxracer33x !!! This is Great. U just save me a lot of time
searching for this info as i am buying a new fork. Btw, real nice bike u got there !!
Seeeriously easy Livin
this would make a good sticky
Good thread. How about some data on the cheaper forks that people would be upgrading from?? You've got the Darts covered, but how about Suntour, etc.
Originally Posted by Vtolds/Dremer03---- "assume any bikes left unlocked and unattended are free to take"
Some more a2c info is available here: http://www.velik.org/components/com_...le=AxleToCrown
upd: url fixed
don't take this the wrong way, but if you have a suntour than don't worry about the axle to crown height as it has not as much of an importance
a2c
Well, since all forks have an axle to crown height, I have to disagree with your statement. Maybe I just don't understand what you are trying to say. Please explain.
Actually, we should leave this thread free of this kind of discussion and let it be a gathering of data, so don't explain.
Absolutely Bloody Marvelous!!! Brilliant Work!!!
Cool thread. Very helpful.
mr. wonderful
Cool and great Thanks!
Totems are 40mm btw.
Busted!!!
Thanks! Its easy to miss that stuff when your going down the list.
Hopefully Ill get teh 29er stuff and a coupl more manuf. done friday. If not early next week for sure.
So you are saying that a person upgrading from a 100mm suntour fork does not really need to care what the axle to crown figure of the old fork was when selecting a new one?
I guess that goes for Marzocchi now too...
Sorry to see that DT Swiss didn't make the list.
My DT Swiss EXC 150 20mm TA is 520mm (so slightly less then the official reading). Others have given the same number.
How are you going with EXC, worth the money???
It's still in the box... Hopefully I'll get it togeather today, and get to ride on the coming weekend.
They certainly look fantastic and Im hoping they perform as good as they look cause the light weight could put my Nomad in the sub 30 pound category.Pm me on how it goes.
nice.
great reference chat, just what I was looking for. thanks!!
this would be a good sticky
Porch
"If we were Vikings, Rocky Mountain aspen stands would be our Vahalla and its singletrack our bounty" - Mtn Flyer Mag #14
Why isn't this stickied? It's super useful, yet it was almost hard to find...
sweet thread! really helpful for anyone looking to get a fork compatible with their frame, or vice versa. +1 to the idea of this being a Sticky.
- You may not post replies
- You may not edit your posts
Forum Rules
