Page 4 of 4 FirstFirst 1 2 3 4
Results 76 to 85 of 85
  1. #76
    Reputation: Jamenstall's Avatar
    Ive checksd a couple of sites and they have the axle to crown listed as 525mm.
  2. #77
    Reputation: Renard_Rouge's Avatar
    Do you know the AC of a Float 34 2014 in 160 mm ?
    Reputation: shapirus's Avatar
    Any data on the 150mm variant of RockShox Sektor?
  4. #79
    nm, figured it out: the 15mm axle 150mm travel variant is spec'd at 529 +/- 5mm.
  5. #80
    May 2013
    Anyone have Rock Shox link to A to C lengths for all their forks?
  6. #81
    Reputation: nallacious's Avatar
    Oct 2010
    Quote Originally Posted by Fat Urkel View Post
    All Specification Sheets | Bike Help Center | FOX
    For a 27.5 wheel, I want to compare the Pike, Fox 32 and 34, and MRP for 120mm and 130mm fork travels to install on the Pivot Mach 4 medium I have on order. I am interested in comparing weight and axle-to-crown length mostly.
    For MRP I can only find their main page, which only says "WEIGHT: 4.3 lbs. for 26/27.5", 4.4 lbs. for 29"; AXLE-TO-CROWN HEIGHT: 553mm for 170mm 26/27.5", 558mm for 150mm 29."
    For Pike this is all I can find so far: 1861g (4.10 lb)
  7. #82
    Hi, does anyone know what the Mazzorchi 350 (27.5/160mm) forks A2c height is?
  8. #83
    Nov 2015
    Im looking to get a new pair of downhill forks for my bike but i have to get a thru bolt hub for my front wheel. They state that the crown pitch is 140mm but i have no idea what length hub I need to get; a 110mm hub, 100mm hub?
  9. #84
    Dec 2011
    === White Brothers ===
    Loop TCR 29er 80mm: 489mm
    Loop TCR 29er 100mm: 509mm
    Loop TCR 29er 120mm: 529mm
    Loop TCR 29er 130mm: 539mm
    Loop TCR 29er 140mm: 549mm
    From here, with rakes etc. specs all there too:
    http://www.cyen-bicycles.com/files/L...IST-Sheet1.pdf
  10. #85
    Hi guys I havea doubt.
    Right now I have a 2009 Rock Shox SID Race 26' 100mm. I would like to trade it for a Magura TS8 100mm.
    Right now the 27.5' prices are cheaper than 26. The axle crown difference is 13mm.
    Do you think it will hurt? My frame is a 2012 Trek Elite 9.9SSL
    I don't plan on converting it to 27.5' (at least for now).
