Results 1 to 3 of 3
    May 2013
    Fork vs shock length
    I will be getting my first FS soon. When setting sag I have read you want to be 25 -30% of the tube length. The bike I am getting has a 140mm shock and fork. The fork seems to have much longer tubes even through the travel is the same? Do you I simply take 25% of 140mm and not worry about how much tube is exposed? Bob
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Yes, 25% of the tube length.
    Rear suspension uses leverage ratios to (i.e., 2.5:1, 2.8:1, etc) to compress the rear shock at a rate less than the actual movement of the axle. So, while the shock might compress 10mm, the rear axle is moving 28mm (depending on ratio).
    The shock itself probably only has the ability to move ~1.5-2.5", again, depending on leverage ratio.
    Death from Below.
    May 2013
    Thanks I did not know that. Bob
  1. Edit: Dumb question, nevermind
    By trhoppe in forum Shocks and Suspension
    Last Post: 08-11-2014, 06:38 AM
  2. Shock length question
    By Vader1 in forum 29er Components
    Last Post: 11-12-2013, 02:51 PM
  3. shock length?
    By gearless in forum Cannondale
    Last Post: 10-11-2013, 02:00 AM
  4. shock length
    By ktm520 in forum Shocks and Suspension
    Last Post: 04-01-2013, 05:56 PM
  5. shock length
    By applehead110 in forum Jamis
    Last Post: 11-28-2012, 08:47 AM
