FAT BIKES
WINTER APPAREL
TRAINERS
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 101 to 125 of 144
  1. #101
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by stillkeen View Post
    I have read on a few locations that the older Fox forks use a Torco RSF Medium oil (see pictures). Attachment 773728Attachment 773729
    The newer Fox oils are apparently made by someone else, and they are not the same (weight, color combination) as any they sell to the public. There seem to be 'red' and 'green' versions.
    Green:
    Has a cST of 47, but called 10wt.
    Attachment 773731
    Attachment 773732Attachment 773733
    I read Rockshox don't use Torco, but have yet to work out more about what they might use.
    NOTE: I am working under the assumption that if the bottle is the same as a motorcycle brand, then it's almost certainly made by them, but may be a grade/mixture that isn't sold direct.
    My Torco RSF Medium is widely claimed to be exactly what Fox use. I have bought a bottle (1/3 the price of Fox fluid) and have used it successfully (although I don't know if I could tell if it was not exactly the same). The Torco/old Fox is only specified for a few forks, most use the newer bottles.
    Hi, take a look at this chart here :
    Suspension Fluid - Pvdwiki
    And in particular this exact file :
    But yes, you could try to find the equivalent in motorcycle world. Many of us here uses Bel-Ray Motorcycle fork oil, I've been using it to replace 5w to 15w RS and Marzzochi oil (Marzzochi is Golden Spectro) and it's all good. Honestly if you take the time to do your maths, you may end up with a way cheapest oil cost than that uberly expensive Fox stuff.
    Good luck
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
  2. #102
    They Call Me "B"
    Reputation: Brannonpack's Avatar
    Jun 2013
    New to MTB'n... Need help with Fork adjustments... Explanations? Can someone explain when I would "Lockout" my forks when riding? Have a ROCKSHOX XC 32 TK 29er Fork... I ride REAL rooted/stumpy trails in the hills of the Ozark Mountains in Arkansas. Read some stud 'bout people blowing out there shocks on roots and wanted to know when it was appropriate to lockout the travel on the fork?
    Also... Can someone explain the external rebound adjustments? I'm 6'3 and 200lbs on a NORCO Charger 9.1 29er... Is there a preferred point or is it personal preference for riding rough terrain?
    Thanks...
  3. #103
    Jul 2013
    Hi to all. I'm new to a forum so i hope I'm in the right theme. I have Giant Reign 1 2013 and want to service fork (talas ctd 150mm). I was googleing without resoults, just want to find manual on how to do it, oil levels. Fork works like it is pretty dry :S. Hope someone can help.
  4. #104
    Jun 2012
    Quote Originally Posted by sch3ll3 View Post
    Hey I just serviced my fox float fork myself for the first time the other day and it wasn't too bad! My suggestion is to check out what you can find searching on youtube "how to service fox talas" and you should have not problem doing it yourself.
  5. #105
    Reputation: sagitt77's Avatar
    Oct 2010
    Sorry about digression but I didn't find any proper topic and I don't want to start a new one. I have a question, maybe silly (or even stupid...) but I wonder if a Rock Shox Reba 29' 2012 lowers would match to Reba 26' 2012 upper legs? I'm thinking about not-expensive 26' fork adaptation to biggest wheel....
  6. #106
    Aug 2014
    Hi, thanks for the mass of information in this thread. I am shortly going to be attempting to service my Thor's Damper, replacing the oil etc. I have read the oil volume pdf and overviews provided in 2nd post but was wondering whether anyone had attempted this themselves or had any info detailing the damper service procedure?
  7. #107
    Aug 2014
    that will work just check the casting depth in the foot-nut area.
  8. #108
    Aug 2014
    this is what im replying to above
    Quote Originally Posted by sagitt77 View Post
  9. #109
    Sep 2014
    I wonna know the difference between
    sr Suntour xct v2
    and
    SUNTOUR - M3030 DS 26
    so if anyone knows anything i would be grateful
  10. #110
    Aug 2014
    looks like both are about the same one is a disk (3030) and the other in v-brake
  11. #111
    Sep 2014
    Quote Originally Posted by SuspensionKing View Post
    They both have v-brake and disk versions i have V2 in disk+v brake version
    but i have an option to replace it for 3030
  12. #112
    Reputation: Shakester's Avatar
    Jun 2012
    Quote Originally Posted by Brannonpack View Post
    Thanks...
    People usually use the lockout during climbs to prevent the front end from bobbing, especially when they're climbing while out of the saddle. It also comes in handy on pavement and smooth trails.
    As for the rebound adjustment, the setting could be different for everyone. You don't want it too fast where it bounces the front of the bike up. Turn your rebound to the slowest and back it off a few clicks. Then jump off a curb or roll down one to test it out.
  13. #113
    I bought a 2014 Intense Spider comp demo bike a month ago, only did a few short rides, but the fork was always harsh over small bumps, even using ~20psi less than Fox recommends to get 20% sag, so I decided to drain/inspect the lowers, just in case they were underfilled, or dirty (I have no idea how much demo riding it got over their 5 events), or whatever. (the fork is a Fox Talas 34 29er CTD Adj) - When I knocked free the shafts, there was a good puff of air released, then both legs drained a decent oil volume, and the seals/wipers looked good, still had clean white grease on them, so I put it back together and refilled the bath oil. Then, the fork felt night and day smoother, and I had to increase pressure back to what Fox recommends to get 20% sag.
    So, for the lower(s) to be pressurized, is it most likely a Talas seal leak, or can it "just happen" after being ridden only a few times over the season?
  14. #114
    I have a 2014 Float-X CTD. Does the piggy back require any servicing? Or is it just the primary shock?
  15. #115
    Reputation: kodo28's Avatar
    Quote Originally Posted by lucifuge View Post
    It depends on the service you are doing...
    30hrs service > only seal kit
    100hrs service > Inspection, complete tear down and rebuild of damper, including new seals, oil and nitrogen recharge . New air seals and new DU bushings
  16. #116
    Reputation: SRvancouver13's Avatar
    Hi All.
    Just thought I would post a link to our service page. It goes over service intervals and if needed there are prices for sending forks in to us for services if they cannot be provided by a shop or at home.
    Cheers. Nick
    SR Suntour North America | Suspension Service Programs
    SR Suntour warranty/technical advisor
  17. #117
    thanks for the info! cheers
    Quote Originally Posted by kodo28 View Post
  18. #118
    FOX Float X CTD
    do anyone knows where the shims for tune are in that shock?
    I now know that this shock is different then the regular CTD.
    the regular don't have shims, and have a boost valve.
    the Float X have shims, and dont have boost valve.
    where are the shims that control the Rebound and Compression?
    what do they change to make this shock F or M or L tune?
    thanks
  19. #119
    Fork and Shock Service Information
    I accidentally over torqued the bold on the damper side of my 29 float ctd and forced part of the damper mech through the bottom. No damage to the lower assembly, but obvious damage to the lower damper mech.
    My question is: has anyone had any experience with FOX and their RA request/repairs? Whats the usual turn around time? How much did your repair cost? And are there any alternative places to have your fork repaired?
    Ive tried looking for parts, specifically a 32 CTD damper mech for 29 inch and 100mm travel. Nothing out there or I don't know where to look.
    Any info will be much appreciated.
  20. #120
    Huckin' trails
    Check with Push Industries. They specialize in suspension work and tuning. While you're at it, have them do the full service too, if you ever send the fork in. HippyTech Suspension is another placebo check out too.
  21. #121
    Thanks will try tomorrow
  22. #122
    Anyone know of an online parts dealer who would carry an air side top cap for a rockshox reba rlt. I did a search and couldn't find anything. Thanks
  23. #123
    Aug 2013
    Fox inline rear shock oil change/bleeding
    Someone might find this useful. I will later add more pics, more detailed information, etc, but now I am too lazy. You can comment on the link, and I will try to make it better.
    https://**************************/d/1...it?usp=sharing
  24. #124
    GMM
    GMM is online now
    Reputation: GMM's Avatar
    Just changed the oil and seals on my Fox 34 CTD FIT (29er if that matters). Unfortunately, now I can barely get the fork to budge and it is making a slight knocking noise when I push down hard on the fork. I emailed Fox before I changed the oil and put in their recommended oil (30 ml in each side of the lowers) volume. I put in my prior air pressure 175 psi and there was zero sag. I lowered to 150 psi and it is still very difficult to get the fork to compress beyond an inch or so. Any ideas of what I screwed up?
  25. #125
    any chance it pushed the seals back into the fork when you put lowers back on stancions? i.e. they didnt stay put and its putting resistance where it shouldnt?
    Quote Originally Posted by GMM View Post
Follow MTBR on Facebook
