Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 101
  1. #76
    Sep 2012
    I tend to agree with your position on cleaning and re-lubing the unit. I am hardly a an aggressive rider and do not beat up my bike at all so there has been no damage to the fork in that respect. As a matter of fact the dust wipers are dry on both sides of the fork. The only oil I saw leaking was from the little red rebound controller on the damper side. I am going to get the oil and give it a go with a good cleaning fill it back up per specks and ride. Worse thing to happen is I find a bad oring or do a rebuild over the winter. Thanks for your input tonight David.
  2. #77
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by BruNut View Post
    Worst case you can always get a replacement o-ring at the hardware store... And Judy Butter on all friction parts and o-rings, glide rings and seals and into the dust wipers lips.
    You're welcome
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
  3. #78
    Sep 2012
    O-ring chart
    Just came across a thread on O-ring sizes David! Looks promising.
    forums.mtbr.com/shocks-suspension/o-ring-sizes-rs-revelation-reba-pike-inside-579868.html
  4. #79
    Huckin' trails
    Look interesting... Should spend more time there soon
  5. #80
    Sep 2012
    Hi,
    I have rebuilt my son's Specialized hotrock 20".
    I put the front forks through the powder coating oven before realising that there are plastic guides in the forks that the tubes run inside. These have now melted.
    Does anyone know where to get replacement?
  6. #81
    Sep 2012
    The job went well. Had a couple "crap now what" moments and replaced one o-ring. Refilled the oil to specs and everything works like new again. Thanks to all who care enough to share their experiences with all. This is a great resource and sharing center for all things mountainbike!!
  7. #82
    Oct 2012
    marzocchi ata with coil
    hi there,
    i recently purchased a fork with ata,,when i went to service the cartridge i found it had a coil installed,,is there any info on this anywhere ?
  8. #83
    Nov 2012
    Can see this took a lot of effort so thanks
  9. #84
    Nov 2012
    Also any tips for servicing the fork on a 2012 hardrock
  10. #85
    Huckin' trails
    Quote Originally Posted by AIDONN View Post
    Yeah, find out what fork you have. Which manufacturer and model.
  11. #86
    2012 Reba 29er RLT (15mm Maxle version) service question
    I have bought a 29er Reba with 15mm thru-axle lowers and I surprised how should I loose the nut at the air side. It's soo deep inside the legs! I have just found SRAM's service manual .pdf but there is only a note to this question: "For hollow bottom fork legs you will need to use a deep 10 mm socket to loosen and unthread the air shaft nut."
    Which socket tool should I search for (especially if I would like to use a torque wrench for proper tightening)?
    ___
    2012 On-One Whippet XC, SS edition w/ 32-18
    2012 On-One Inbred 29er (custom ht w/2x9, trail, fun & race bike)
  12. #87
    Huckin' trails
    Quote Originally Posted by semmiho View Post
    Well you can get a simple deep 10mm socket of the right size for your torque wrench (like 1/2 or 3/8).
    A deep socket is like a regular one, but taller/longer. Any one that fit is gonna do the job.
    I usually have to use a few main tools for fork servicing. A long sturdy flat blade screwdriver, one smaller/thinner, a few metric hex wrenches and 21mm/24mm, etc wrenches or 6-point socket for the top caps depending what's best. Then a regular 3/8 or 1/2 wrench with short, medium and long extensions, and a few sets of metric sockets to find the right fit for every fork. It also helps if you have a pretty complete tool collection in your shop (not bike-related tools, but general tools). Also a few lint-free rags, a nice wide and large container to drain the oil, many paper rolls and isopropyl alcohol bottle for accidental spills and stains, a little flashlight is also useful, and then cir-clip pliers and rubber mallet too.
    Supplies would include new oil, Judy Butter or similar (oil friendly grease), isopropyl alcohol to clean up the old oil, thick grease for the coil springs (if not immersed in oil bath) and music+beer.
    I would also print out tech data and instructions you could need, but them in a binder inside plastic protectors and usually have at least oil volumes and exploded view of the fork, and also a few blank sheets to take notes if needed. This will be your workbook for bike stuff in the future.
    So here ya go
    This is what you need here :
  13. #88
    Suspension Specialist
    Nov 2012
    Great, great thread!
  14. #89
    Nov 2012
    the links to SRAMS rock shox service manual pages under the TORA ...
  15. #90
    Feb 2012
    2008 Pike U Turn issue
    Hi
    I have a 2008 Rockshox Pike 409 U-Turn Coil that I just bought used. When i twist the U-Turn knob to raise the suspension noting happens. It clicks a few times then clunks and the suspension travel stays the same. Any help is appreciated.
  17. #92
    Oct 2011
    Hello.
    Anyone know outside diameter of RockShox Vivid 2008-2011 ifp (maximum OD the aluminum body ifp) and ID of expansion tank.
    I want install Vivd IFP in DHX.
    DHX IFP have 26,8mm OD
  18. #93
    Jan 2013
    Perfect, thank you
  19. #94
    Feb 2013
    nope
  20. #95
    Jan 2013
    Hi! I have Recon Silver (2011) with turnkey damper. Turnkey damper have a code 43-4015-016-010, but in RS spare parts catalog I can`t find the item with that number. Can I use another turnkey damper?
  21. #96
    rebmem rbtm
    Quote Originally Posted by arevuar View Post
    Where did you get that code from, it isn't listed for any of the 2011 Recon Silver's dampers.
    Look on pages 17, 18 and 19 of the 2012 Rockshox Spare Parts Catalog:
    http://www.sportimport.de/wp-content/uploads/2011/07/2012_rockshox_spc_rev_c.pdf
    Standard Turnkey: Part # 11.4015.306.000
    http://www.petracycles.co.uk/rockshox-compression-damper-assy-tora-sl-turnkey-crown-adj-p-69109.html
    http://www.bicyclehero.com/us/rockshox-turnkey-compression-damper-tora-sl-11-recon-silver.html
    http://www.bikeman.com/FK7160.html
    http://www.universalcycles.com/shopping/product_details.php?id=30476
    Remote Turnkey: Part # 11.4015.306.020 seems to be out of stock everywhere.
    Remote Motion Control: Part # 11.4015.306.030 seems to be out of stock everywhere too.
    There is other dampers that would probably work work with your fork too.
  22. #97
    Jan 2013
    Quote Originally Posted by cobba View Post
    This code is written on the damper
  23. #98
    Mar 2005
    Oils: Can we get OEM to Motorcycle Charts?
    I have read on a few locations that the older Fox forks use a Torco RSF Medium oil (see pictures). Name:  Fox 7wt.jpg
Size:  8.0 KBFork and Shock Service Information-0000_torco_rsf_racing_shock_fluid_-.jpg
    The newer Fox oils are apparently made by someone else, and they are not the same (weight, color combination) as any they sell to the public. There seem to be 'red' and 'green' versions.
    Green:
    Has a cST of 47, but called 10wt.
    Name:  fox suspension fluid 10wt.jpg
Size:  27.6 KBFork and Shock Service Information-screen-shot-2013-02-20-11.33.09-pm.png
    I read Rockshox don't use Torco, but have yet to work out more about what they might use.
    NOTE: I am working under the assumption that if the bottle is the same as a motorcycle brand, then it's almost certainly made by them, but may be a grade/mixture that isn't sold direct.
    My Torco RSF Medium is widely claimed to be exactly what Fox use. I have bought a bottle (1/3 the price of Fox fluid) and have used it successfully (although I don't know if I could tell if it was not exactly the same). The Torco/old Fox is only specified for a few forks, most use the newer bottles.
  24. #99
    Mar 2011
    How much would it cost to upgrade the damping on a Rockshox Sektor R to motion control? What parts do I need and how do i get them? Universalcycles.com seems to have the right part listed for $61 but it's out of stock. (can't post links, sorry!) I haven't found the same part anywhere else.
  25. #100
    Mar 2013
    Hello- looking for a service manual for my wife's RST Gila T4 fork on her 2004 Specialized Hardrock. The links at the top of this thread appear broken, and I got no reply from the email listed on the RST site. Any tips? Thanks!
Hot Deals
Contests
Latest Mountain Bike Articles
