    Reputation: two-one's Avatar
    New question here. Enduro seals on a Fox F29, foam ring position?
    I'm replacing some seals on a Fox F29 (2012) with Enduro seals, but I'm a little confused about the assembly order. The (ancient) manual for the enduro seals says there is a stepped position above the upper bushing where the foam ring is supposed to be, but my lowers seem to lack this "stepping". Whenever I place the foam ring, and press in the oil seal... the foam ring gets squashed to 2mm in height, so that's probably not the correct way.
    Did anyone run into the same issue?
    The foam ring goes between the oil seal and the top fork bushing. I install the oil seal, install the wiper, then I pull the oil seal up against the bottom of the wiper, and then I install the foam ring.
    how can you "pull" the oil seal up?
    With your fingers.
  1. new Enduro seals on Marverick
    By fstfrd15 in forum Maverick
    Last Post: 07-26-2012, 09:24 AM
  2. Enduro Seals vs Fox OEM
    By AndyN in forum Shocks and Suspension
    Last Post: 06-16-2012, 09:09 AM
  3. Middle Ring in Outer Position?
    By Lelandjt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2011, 09:20 AM
  4. Q on enduro fork seal foam ring
    By crazyjeys in forum Shocks and Suspension
    Last Post: 04-11-2011, 09:36 AM
  5. enduro seals
    By metajkt in forum Shocks and Suspension
    Last Post: 02-20-2011, 02:08 AM
