Results 1 to 8 of 8
    Reputation: TwoHeadsBrewing's Avatar
    Effects of different fork oil weights on behavior
    The fork seals on my Revelation 2012 150 are about done, so I figured to do a complete service. I'm wondering what difference, if any would be noticed by changing from the stock 15wt oil to 10wt oil. Has anyone done this and noticed anything different?
    "Got everything you need?"
    Thicker oil will increase the dampning (resistance of oil flow)- slower rebound & more compression. I haven't heard of anyone going thicker on the RS fork's, I tried 2.5wt and returned to 5wt.
    **Edit** missed the boat, didn't realize you were reffering to semi-bath oil. I have tried all sorts of brands in both 10wt, 15wt & 5-30wt syn. motor oil. Never noticed any change. I currently run syn. motor oil because it is cheaper than fork oil.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Keep in mind that unless comparing the two oils from the same manufacturer, the 'weight' is a poor comparison of viscosity at best. If changing oil viscosity for the purpose of changing damping/rebound characteristics then be sure to compare the cSt @ 40degrees. That's a true measure you can use between all suspension fluids.
    This chart is a little out dated but gets the point across.
    Attached Files Attached Files
    Yes, I'd be using either the RockShox or Maxima fork oil which is the same thing. Stock recommends 15wt, but I'm thinking I'll try the 10wt.
    EDR
    Jun 2005
    Re: Effects of different fork oil weights on behavior
    RockShox oil used to be made by Torco. But I think you are right in that nowadays it's actually Maxima oil.
    Anyways, you seem to know what you're doing. Give the different oil try and if you don't like it you can always swap it out.
    Changing the weight of the bath oil won't make a difference, except it may lubricate less since it will run off the stanchions more quickly. Stick to 15wt for the bath oil.
    If you want to change the damping characteristics of the fork, you need to change the damper oils viscosity. That oil is located in the upper portion of the right stanchion. Stock is 5wt. 2.5wt will speed up both rebound and compression, mainly on the low speed side of things. 7 or 10 weight will slow things down. I prefer lower weight oils in RS forks, as I feel they tend to spike in the chunk.
    Reputation: trailbildr's Avatar
    Dec 2004
    Yes, that.
    Your lubricating oil should be close to spec. You won't notice much of a difference in performance. The damper oil change would make a difference but you aren't talking about that. Or did you know that?
    There's damper oil (5wt) and there's bath/lubricating oil (15wt). And they don't mix.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    You could replace the 15wt bath oil with Mobil1 synthetic, lots of discussion on these boards about it. I've been using it for several years in my 2010 Rev and Lyrik.
    As others have said, changing the damper oil is where the difference is at. I also prefer to use 2.5wt in my RS forks, it allows them to respond faster making them feel smoother over small chatter.
  1. Weights for Sworks HT 29 Frame, Fork and Tyres
    By S-Worker in forum Specialized
    Last Post: 08-20-2012, 06:40 AM
  2. Using a 100 mm instead of 80 mm fork. Effects ?
    By calvinhobbes in forum 29er Components
    Last Post: 02-25-2012, 01:57 PM
  3. Effects of different weights of cassettes
    By Veda in forum Weight Weenies
    Last Post: 06-22-2011, 11:14 AM
  4. Comparable Fox Fork Oil Weights?
    By Mojo Man in forum Shocks and Suspension
    Last Post: 03-17-2011, 03:56 PM
  5. Fork weights? Lefty vs. standard
    By ro7939 in forum Shocks and Suspension
    Last Post: 03-15-2011, 07:20 PM
Members who have read this thread: 16
