Results 1 to 2 of 2
    May 2010
    New question here. Dt swiss xrm service guide!! HELP
    Hello to all, since I have a dt swiss xrm for a year, I should be doing maintenance on the hydraulic part and the part of 'air since the fork has worked for 10000 km mountain bike.
    The part of 'air and easy to do maintenance on tables and methods of removal, but in the hydraulics scive no nothing, and I have not found anything in this regard.
    I know that as we go into RockShox oil hydraulics also in the dt swiss should go but I can not find that type of oil and how much should go for any type of fork.
    Someone has tables of how much oil goes into the fork on both sides?
    What are you trying to do:
    Service the lower legs and the air spring
    OR
    Service the lower legs, air spring AND damper?
    If you're servicing just the lower legs, DT have a video for servicing Single and Twin Shot forks on Youtube. Regarding the airspring, watch the DT video for servicing the Launch Control forks - this shows airspring strip down/rebuild.
    If you want to service the damper, this requires special tools and instructions, so it's back to a DT service centre.
Hot Deals
Contests
Latest Mountain Bike Articles
