Results 1 to 5 of 5
    Do I need new mounting hardware?
    I have a 2011 Trek HiFi Deluxe and I'm putting a Rock Shox Monarch RT3 in place of the Fox RP2 that came on the bike. Do I need new mounting hardware or can I use the ones that came on the bike? Thanks!
    Reputation: Dougal's Avatar
    The eyelets are the same nominal size, but you may find the tolerances are different and the fox hardware might be a very tight fit.
    Try it and let us know.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    If it doesn't fit, how do I find out what I need?
    LightJunction.com
    Reputation: lightjunction's Avatar
    Your best bet might be to order a parts kit from your LBS. SRAM has a pretty helpful tech line that will be able to tell you what you need though. I'm fairly sure they don't sell direct though, so you probably won't be able to get more than a part number/name from them.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    First you try it.
    SPV Devolve
