Results 1 to 2 of 2
    Feb 2005
    Damper interchangeability between Reba and Revelation
    Is it possible to swap the compression and rebound damper internals between the 2010 Reba and 2010 Revelation?
    The reason I ask is that the Reba is a TEAM version with blackbox compression and rebound, while the Revelation is a regular Motion Control. Since the Revelation is my primary fork, I'd like to put the upgraded dampers in it from the Reba.
    Thanks for anyone who has info on this.
    I have swapped RS dampers easily between similar size stanchion / material RS forks. Sometimes I look @ RS parts PDF, call RS or just give it a try.
