Hi all :thumbsup:
Here is the 4th Version of my Fox DHX 3/4/5 Service Guide
It shows you how to completely service (about 98%) your DHX, including the rebound and propedal assemblies. Servicing the rebound assembly will require careful use of a propane torch, so before commencing work on your shock, be sure you uderstand what you are doing by first reading the method in which to use the propane torch.
Make sure you download and read through the tutorial carefully before commencing work on your shock
Shock Models Supported;
2005 - 2009 Fox DHX 3/4/5 Coils
2010 Fox DHX 3/4
NOTE: CERTAIN DHX 5 THAT CAME STOCK ON SPECIALIZED SX TRAILS HAVE UNADJUSTABLE BOOST VALVES, MEANING THERE IS NO AIR VALVE FOR YOU TO ADJUST, INSTEAD THEY ARE FACTORY CHARGED WITH NITROGEN
DO NOT ATTEMPT TO SERVICE THESE SHOCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Download Links:
( I know the hosting sites arnt liked by many people, but sorry it will have to do for now )
Guide:
http://www.mediafire.com/?lotejczmzz0
Enjoy boys and girls
Also if you use this guide please report your success, also CONSTRUCTIVE critisim is welcomed, oh, and do not ***** about how i used a shifting wrench, its all i had, use a spanner if you wish
Cheers!
2010 Fox DHX 3/4
Download Links:
Guide:
Cheers!
