    Checked fork pressure upside down, sprayed in face with oil, fork now locked up
    I must have been having some brain issues last night, as I attempted to check the pressure on my 2014 Manitou Marvel Expert while the bike was hanging upside down from the garage ceiling. I was promptly sprayed in the face with semi-bath oil, and now the fork is locked up and won't move, even with no pressure in the air spring.
    I was going to have to take the fork apart anyway to lower it from 120mm to 100mm, so I'm not concerned about having to do any disassembly. I just want to make sure that I didn't somehow damage the fork in any way. What would be causing is to lock up and not move?
    Quote Originally Posted by savechief View Post
    What you lost is not bath oil but rather the oil on the air piston. I would remove the top air cap and add back about 5cc of motor oil.
    That's what I figured, but what about that would cause the fork to lock up and be immovable?
    Reputation: Vespasianus's Avatar
    Well, when the air piston has no oil and lubrication, it could cause some stickiness.
    On MTBR, the reputation is infamous.
  1. Mirage UPSIDE DOWN / RIGHTSIDE UP fork
    By Fakawi in forum Shocks and Suspension
    Last Post: 03-30-2014, 08:02 AM
  2. fork won't stay locked
    By 2logicl in forum Shocks and Suspension
    Last Post: 02-23-2014, 07:30 PM
  3. Marzocchi 66 RCV fork - determine air pressure in fork?
    By mrrhtuner in forum Shocks and Suspension
    Last Post: 01-19-2014, 11:55 AM
  4. Fork locked up?
    By NFLcheesehead1 in forum Beginner's Corner
    Last Post: 02-17-2013, 06:58 AM
  5. Turning fork upside down bad?
    By Radamus in forum Beginner's Corner
    Last Post: 01-04-2013, 06:34 PM
