Results 1 to 11 of 11
    Changing Monarch from 2.0 to 2.25" stroke?
    so,
    I can get a good deal on a used monarch plus in 7.87 x 2.0" stroke. Given the bike I'm putting it on, I would like to have the option to run 2.25" stroke.
    How does the monarch limit its stroke? is it just a spacer I can take out, or is it a different seal head with more material on it like fox uses?
    Has anyone done this?
    H.
    Dec 2013
    any news if possible to change the stroke
    hy
    i┤m in the sam Situation as you have been with the Monarch stroke
    do you have found a solution?
    is it possible to Change or remove a spacer ?
    would be interested in your experience
    nope. Not an easy change, or an internal spacer. You gotta get the different shock.
    That being said, I ran the 2.0 stroke and started to like my bike a bunch at 125mm rear.
    Dec 2013
    thank┤s for letting me know
    ;o)
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    If you sent the shock for service by Rock Shox, could they extend the stroke?
    Just seems ridiculous to buy a whole new shock and lose all that money for an increase of 1/4"
    GIS/GPS Pro using ArcFM for Utility Mapping - Always willing to connect with other MTBers in the industry.
    I agree, it is. Switching between the strokes on my rig gains ~15mm of travel. Much of the same feel and difference in ride can be achieved by going from 20% sag to 30% sag.
    Not worth spending money on to go from a nice, functional shock to another nice, functional shock. More like something to consider when going from a blown, OEM level shock and you're spending top dollar to get exactly what you want.
    Dec 2013
    i┤ve been in the Situation that i had None,
    in complete not available i managed it with spareparts,
    Damper unit, air can, remote, about 30 % more to pay
    ;o)
    Dec 2012
    Some bikes can gain up to 25mm of travel, which makes the difference between a trail bike and something you can take to a park.
    Reputation: ktm520's Avatar
    It would probably be about 200$ in parts. You have to replace the damper body, damper shaft, and air can.
    Dec 2012
    Honestly I think that'd be worth it to be able to use a shock on two different frames. You'd probably lose $200 reselling a used shock and trying to pick up either a new one or finding a used one in the proper size.
    Dec 2013
    go .
  1. Bump in the stroke Monarch R
    By mrmas in forum Shocks and Suspension
    Last Post: 04-30-2013, 10:53 AM
  2. Changing tunes on a RS Monarch 2.1
    By Dutch in forum Shocks and Suspension
    Last Post: 08-12-2012, 01:59 AM
  3. Changing IFP Pressure on the Monarch RT3 on a Tallboy
    By hillharman in forum Santa Cruz
    Last Post: 03-21-2012, 11:29 PM
  4. Replies: 1
    Last Post: 01-20-2011, 11:06 PM
  5. Replies: 2
    Last Post: 01-04-2011, 09:31 AM
Members who have read this thread: 7
