Results 1 to 9 of 9
    "El Whatever"
    Reputation: Warp's Avatar
    CCDB Air... how to open air canister?
    Cane Creek claims the air canister on their new CCDB can be serviced without touching the damper (or so I've read).
    I believe them, but I looked at this pic and I can't figure out how, so obviously I'm missing something. Kind of same thing for the Vivid Air, but on the Vivid air you can get the air adapter from RS and do it at home.
    Any ideas??
    Do you have to send the shock to Cane Creek every time it needs service? Maybe a competent Moto-shop?
    Quoting...
    "Having said that, one of our design criteria for the DBair was that it should be serviceable without opening the damper, meaning you can service all of the air seals without opening the damper ,and we accomplished that."
    Cane Creek DBair Shock ? The Full Story (video) - BikeRadar
    Check my Site
    Email : support@canecreek.com . Pretty sure they could tell you if the shock's air sleeve is user serviceable.
    Reputation: Deerhill's Avatar
    Dec 2009
    thanks warp, now i want one
    moaaar shimz
    Reputation: tacubaya's Avatar
    I have the service manual for the CCDB. It's quite a hassle, but given the tools I'd be willing to do it for ya
    Oct 2011
    Quote Originally Posted by Warp View Post
    Any ideas??
    Yes, watch the video on Pinkbike - search DBAir. They say you remove an O-ring in the back and the whole air can will slide off of the hydraulic system. You will also be able to vary the volume in the air by adding inserts, in order, to tune it for different leverage ratio bikes.
    Reputation: tomacropod's Avatar
    Gravedig. Tacubaya, tried to PM you for the manual to do this but your inbox must be full. Has anyone had any luck getting the damn inner air can off? Taking the outer off for volume adjustments is cool, but doesn't give access to any of the dynamic seals for a sleeve service.
    - Joel
    Cycling is Serious Business.
    Just take the the outer can off and suck some float fluid through the transfer ports. Unless your seals are leaking.
    CCDBAIR air sleeve service
    You can modify a park tool HT2 spanner Name:  d45c0ee6c7610239d5bf2512b78e2a6929f1850e_430x390.jpg
Size:  10.3 KB to open up the negative chamber where the blue seal sits. It is the same tooth count as a BB and you just need to open up the jaws of the spanner quite a bit, it is still useable as a BB spanner. Clean and grease/ 3ml gear box oil in here and you are lubed up for a couple of months.
    For completely removing the can and replacing the seals you need shaft vice grips of the right diameter, Name:  shaft-clamp-set.jpg
Size:  34.2 KB a set of these is highly recommended for all suspension tinkerers. Slide the air can towards the piggy, clamp the inne shaft, and unscrew the eyelet (locktited), slide air can off, pick out the seals, relube, reverse. Ta da!
    Tools : BBI Universal Shaft Clamp Set
    Park Tool Co. BBT-9 : Bottom Bracket Tool : Bottom Bracket
  1. Why the low volume air canister?
    By Yody in forum Ibis
    Last Post: 07-30-2009, 04:33 PM
  2. Can't unscrew 3-way air canister...
    By Haggis in forum Shocks and Suspension
    Last Post: 11-21-2008, 12:20 PM
  3. fox float with different canister
    By saturnine in forum Shocks and Suspension
    Last Post: 03-31-2008, 09:22 AM
  4. Rp23 Air Canister on the Rp3?
    By dulyebr in forum Shocks and Suspension
    Last Post: 07-23-2006, 08:43 PM
  5. DHX Air 5.0 canister removal
    By techFiend in forum Turner
    Last Post: 06-21-2006, 10:38 PM
Members who have read this thread: 4
