Results 1 to 7 of 7
    May 2012
    cane creek installation help
    Hello ! I ordered a cane creek inline coil and the shock is already delivered and I'll be back home on monday. It's gonna replace a monarch on my devinci troy xp but I am lost about all the bushings diameters and mounting hardware kit....
    Am I gonna be able to use my troy bolts to mount the cane creek or do I need a special kit for that ?
    May 2012
    edit : I am talking about the black cylinders that goes in the bushing here and the spacers
    Jul 2017
    You might need a press to install the bushings and mounting hardware. I'd take it to a bike shop for proper installation. Depending on how big or small the eyelets are, you may be able to use the stock mounting hardware.
    I no longer like to party. But I like the idea of it.
    Apr 2014
    The shock should have the bushings already installed and rockshox mounting hardware might fit. It might however be a good idea to use new mounting hardware if there is any wear. Just measure the bolt diameter and width and you can order it at any bike shop.
    More info The Definitive Guide to Cane Creek Double Barrel Eyelets and Hardware
    Sent from my Moto G (4) using Tapatalk
    standard 12.5mm hardware will fit the line coil
    May 2012
    You mean 12.7 mm I guess ? So it will probably fit my coil then and I hope so, I don't want to lose 12 days of riding before I get the parts !
    Jul 2015
    Cane Creek should send you the correct bushings to fit the hardware currently on your bike if you ordered it using the bike selector on CC's website
    Sent from my XT1585 using Tapatalk
  1. Cane Creek 110 Head set installation Help
    By DAnREal in forum General Discussion
    Last Post: 09-19-2012, 05:24 AM
  2. SS2 Cane Creek help
    By kntr in forum Intense
    Last Post: 06-15-2011, 11:27 PM
  3. Help Me Find A Cane Creek 110 Interlok Spacer Kit
    By jonshonda in forum 29er Bikes
    Last Post: 06-14-2011, 09:29 AM
  4. Help with Cane Creek 10 series ZS44 headset?
    By Drew Diller in forum Tooltime
    Last Post: 04-25-2011, 12:29 PM
