Results 1 to 5 of 5
    Can you get a rear suspension with lockout on a 9inch rear shock bike? 8.75 size
    I love riding my downhill bike and being able to tear over anything but most of the time in
    order to do that you gotta pedal up something and downhill bikes arent the easiest to do that
    with. I was wondering if there are any rear suspensions out there that have lockout for a
    suspension of 8.75. the bike it goes on has 9 inches of rear travel if that makes a difference.
    www.derbyrims.com
    Reputation: derby's Avatar
    The Roco TST R Coil has a lockout, or near lockout option among 5 on-the-fly compression levels. And is available in a 8.75 size.
    Reputation: 3034's Avatar
    compressing the fork with a dog collar or similar makes climbing a lot easier
    I am here: http://maps.google.com/maps?ll=38.608616,-120.717906
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by nhillerby View Post
    Ive been riding 7 and 8" travel bikes uphill for a long time. The biggest problem is the geometry, the distant 2nd is weight. Modern shocks and suspension designs don't need lockout, not to mention your bike will "buck" on every impact and radically decrease your uphill traction.
    You have to choose your bike wisely to have a decent tradeoff with uphill and downhill performance, but its really easy to get way too wrapped up in weight and the latest designs.
    Reputation: Corvette's Avatar
    Jayem said it.
    If you really want a lockout, there are two more options:
    - DT Swiss EX 200, 222 mm (8.75) with lockout
    - Fox Float RPL, obtain 216 mm (8.5) version and replace the shaft from 222 mm (8.75) DHX Air.
  1. Rear Suspension lockout on Commute
    By pmabe27 in forum Commuting
    Last Post: 08-04-2008, 12:01 PM
  2. Rear suspension lockout
    By gall1972 in forum Shocks and Suspension
    Last Post: 10-05-2006, 09:18 AM
  3. Automatic Rear Suspension Lockout
    By Digitaljs in forum General Discussion
    Last Post: 10-05-2005, 07:05 AM
  4. Is it ok to use rebound control on Vannila R to lockout rear suspension?
    By BudhaGoodha in forum Shocks and Suspension
    Last Post: 12-09-2004, 09:57 PM
  5. Rear suspension lockout
    By Ouch! in forum General Discussion
    Last Post: 07-28-2004, 01:20 PM
