Results 1 to 13 of 13
Thread: Boost forks
    tvt
    tvt is offline
    May 2017
    Boost forks
    I'm looking to purchase a 140mm boost fork and can't choose between the Fox 34 Factory or the Pike RCT3
    Does anyone have any info on which one is a better ride?
    Or any other ones I should be thinking about?
    Reputation: Dougal's Avatar
    In general the Fox is underdamped and the Pike is overdamped.
    Currently the Pike has more aftermarket support to fix that. But the Fox aftermarket is catching up.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    I say neither. Manitou Mattoc or DVO Diamond. If you insist on one of the choices, the Pike.
    Sent from my iPad using Tapatalk Pro
    Riding slowly since 1977.
    Reputation: mullen119's Avatar
    Quote Originally Posted by Cary View Post
    This ^^^
    You can add in the MRP ribbon, but it would be the third choice in my eyes.
    All three are far better than a pike or 34
    Reputation: trailbildr's Avatar
    Dec 2004
    I would rank the current offerings like this:
    MRP Ribbon
    Fox 34 Performance with that Fit/Grip damper
    Pike RCT3
    We've serviced some of the DVO stuff and it's nice but doesn't beat the Ribbon. The Manitou stuff is nice but support (at the retail level) hasn't been great and seals are rarely available from the suppliers we regularly work with.
    The Ribbon has the most versatility I think. DVO uses their tooled OTT adjustment, Ribbon has adjustable negative air for the same outcome. Ribbon is lighter. Twin tube damper, speed-sensitive Ramp Control and damper on Ribbon. Assembled and damper-tested in ColoRADo, customer service as good as or better than anyone else out there. I don't think the Ribbon ride quality can be beat...
    I've only ridden the Mattoc a bit and almost no time on the DVO but I have a ton of time on Pike RC, RCT3 and FAST dampers as well as MRP Stage and Ribbon in the last three years. I work on all of those forks on a regular basis though.
    Just some additional info for you.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    tvt
    tvt is offline
    May 2017
    The DVO Diamond doesn't come in a 29 140mm though just a 150mm right
    Quote Originally Posted by tvt View Post
    Can be set between 130 and 160 mm.
    Reputation: Rngspnr's Avatar
    Feb 2016
    Diamond FTW. MRP is another good choice. Someone I know blew up his Stage numerous times, but I'm sure the Ribbon is a better fork. Once you get a Diamond dialed in you forget it's under you.
    2016 Evil Following V1
    2016 Dartmoor Primal+
    tvt
    tvt is offline
    May 2017
    How is the DVO sapphire?
    Reputation: Raleighguy29's Avatar
    Jan 2014
    Iíve got a 140 diamond on my riot
    No reviews yet. Same design and damper as the Diamond so should be good. It is a bit lighter.
    If you want 29+ space the Mattoc Pro with high speed adjust and plenty more would be on my list.
    Reputation: kragu's Avatar
    MRPís Ribbon just got a PB nomination for best suspension product of the year. Competition isnít all that stiff (hah!), but there are plenty of really happy people on Ribbons, it seems.
  1. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  2. To Boost or not to Boost....
    By hack10 in forum Ibis
    Last Post: 01-28-2017, 10:12 PM
  3. I see Boost xt cranks... Is there xtr Boost cranks?
    By SB Trails in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2016, 09:57 AM
  4. HOPE HUBS Pro 2 Evo/Pro 4 BOOST IS NOT BOOST!
    By yamaha46 in forum Wheels and Tires
    Last Post: 02-12-2016, 08:48 AM
  5. Boost or non-boost fork for 5010v2?
    By furball in forum Santa Cruz
    Last Post: 02-03-2016, 09:10 PM
Members who have read this thread: 4
