Bontrager shock pump, 2 gauges?
Hi
I use this pump: Bontrager: Shock Pump (Model #08306)
However, I'm not sure how or when to read what gauge...? When it's connected to my fork, only the "main" gauge (the one you can see on the picture, see link above) reads.. When I connect it to my rear shock, both gauges reads:
the main gauge reads ~150 PSI, and the secondary shows ~60 PSI.
So should the main gauge ONLY be used for reading the fork pressure, and the secondary gauge only for the rear shock..?
Best regards
http://bontrager.com/support/contact
Post the reply you get from them, it might be useful to others in the future.
The answer I got from Bontrager is:
When pumping the fork, read the gauge showing the LOWEST pressure.
When pumpung the rear shock, read the gauge showing the HIGHEST pressure.
That's it
By Luckyr in forum Beginner's Corner
Last Post: 10-22-2012, 01:05 PM
By aBicycle in forum Tooltime
Last Post: 08-28-2012, 10:09 AM
By AZGroundPound3r in forum Shocks and Suspension
Last Post: 05-12-2012, 05:00 PM
Last Post: 12-31-2011, 11:31 AM
By howdyhowdyhowdy in forum Tooltime
Last Post: 03-21-2010, 12:49 PM
- You may not post replies
- You may not edit your posts
Forum Rules
