Results 1 to 2 of 2
    bomber z3 2001 leaking oil trouble
    help, anyone? my bomber z3, leaks oil on the left side, thru the arch and slider connection even tough I changed the seals with brand new ones.could You suggest a solution?Thanks!
    Code Burr
    Reputation: thebronze's Avatar
    Quote Originally Posted by nikalai
    Make sure the seals under the wipers are not upside down. I accidentally did that once and it was leaking everywhere.
    Also, is your fork one of the older models that bolts together at that junction? I think I remember a fork where the brake bolts had a structural function at that particular place. Maybe check them for tightness if yours matches.
