Results 1 to 5 of 5
    meow meow
    Reputation: b-kul's Avatar
    blown 2011 fox triad
    today i took all of the air out of my 2011 fox triad on my stumpy to cycle the shock and when i compressed it fluid started leaking out of the rebound/ compression lever. the compression lever no longer functions (just spins willy-nilly). do i need new seals or a rebuild or a new shock altogether?
    You will need a rebuild. Triads are somewhat prone to these problems because of the lockout. Rear shocks support so much weight that lockouts are hard on the shock's internals.
    I recommend sending it to Push and getting the Factory Tune. A shock tuned to your weight, bike and preferences will ride better than a generically setup aftermarket shock.
    meow meow
    so then the question is do i get it pushed or try to snag a rp23?
    Reputation: eatdrinkride's Avatar
    Jun 2005
    You'll spend $170 at PUSH for a custom tune/rebuild. Even if you could snag a somewhat new rp23 for $200 your PUSH'd shock will be a far better product. They gut the thing, re-valve it to suit you, your weight your riding style. It's not even the same shock as a stock Fox. My new 575 frame came with a new kashima 2012 RP23. I rode it for 2 weeks maybe trying to give it a chance. Then I took my '08 Pushed RP23 off the shelf and installed that on the new bike. Next day I listed the Kashima coated shock on mtbr classifieds.
    Look I'm not saying it will blow your mind and make you ride 6'' off the ground. It's just a better product for the money.
    meow meow
    alright, thanks.
  1. 2012 Fox Triad II
    By moosington in forum Specialized
    Last Post: 02-07-2012, 05:43 PM
  2. Fox Triad Failure
    By rsb201 in forum Shocks and Suspension
    Last Post: 11-21-2011, 06:45 AM
  3. Fox TRIAD losing oil
    By Phillbo in forum Arizona
    Last Post: 11-09-2011, 01:36 PM
  4. RP23 and Triad.
    By dlorga in forum Shocks and Suspension
    Last Post: 09-01-2011, 05:50 PM
  5. 2011 Triad II - as bad as older Triads?
    By Vermont29er in forum Specialized
    Last Post: 02-04-2011, 08:35 AM
