    Bike will spin out on corners, rubs front tire on inside of fast turns....
    Ive almost got my dh bike dialed. I have one last issue I'm trying to figure out.
    On some fast sweeping and NARROW turns, I have a tendency to rub my front tire on the inside of turns.
    When I say narrow, think 1 to 1.5 feet wide. I try to keep the tire off the inside, and what happens is I over compensate. Not much better.
    I have also spun out the bike 180 degrees on tight corners. Mostly when its loose and dusty.
    Its like, the bike WANTS TO TURN on its own
    On my last two runs at the bike park, I bumped up the LSC two clicks to keep the front higher. From 3 to 5. It seems to have solved my problem.
    Will be doing further tests.
    I think my spring rates are right on. I can probably tune down the LSC in the rear to let the bike sag a bit more.
    I just need a tad bit less grip in the front, and more in the back. Trying to figure if the LSC on the fork is the best way to go about it.
    The bike feels great everywhere else. Takes bumps and jumps with aplomb.
    These things never happen on local runs. Just in the parks when going at terminal velocities. Any advice appreciated.
    As the same with cars........less spring rate more grip....to a cerain degree.
    Also, it could be your weight distribution....raise your bars or a shorter stem?
    Tire with more grip in the rear?
    All this in combination will change the way your bike rides.
    Bit more tire pressure up front? Less in rear? Could help.
    www.derbyrims.com
    Reputation: derby's Avatar
    Try the DH forum. There are some great riders there who know from much experience how to tune suspension and tires and riding skills to get a bike to handle, and can explain clearly to help guide others in the process.
  1. Fast rolling front tire
    By RE50 in forum All Mountain
    Last Post: 05-01-2013, 09:55 AM
  2. Cannot make 29er turn in fast corners
    By kahwel in forum General Discussion
    Last Post: 04-22-2013, 07:11 PM
  3. Front Derailleur rubs rear tire, fixes?
    By Kyuusei in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-09-2012, 05:24 PM
  4. Riding corners fast
    By Steven92 in forum Downhill - Freeride
    Last Post: 07-03-2012, 04:28 PM
  5. 29er Front Tire - Fast Roll, Bites in Corners?
    By CodyWy in forum 29er Bikes
    Last Post: 07-19-2011, 12:38 PM
