Results 1 to 10 of 10
    Apr 2013
    best shock for the money
    I was looking for a new fork to replace my old one. I was looking for something in the 300$ range and in a 29er size with about 100-120mm of travel. I mainly ride singletrack/trails
    details:
    tapered or straight steerer?
    QR or QR15mm?
    B A N N E D
    Apr 2013
    um qr15mm straight. ill end up having to relace my front hub as it came with a qr9mm. my LBS told me thats not too big a deal. what about a rock shox reba
    Apr 2013
    anything is better than whats on my bike now sr suntuor.
    Reputation: tune's Avatar
    Manitou forks that cobba suggested are a lot better than Reba. Manitou ABS+ is modern properly shimmed (both compression and rebound) damper. Reba doesn't use shimmed damper and uses orifice based rebound that will compromise performance.
    Apr 2013
    well you have enlighten me to look again. Manitou looks to be the way im headed unless anyone has any other suggestions? Fox float maybe
    Fox Float is also a good fork with shimmed damper but the price might be a lot higher unless you can find a good deal. Usually Manitou seems to have best price/performance ratio for "short" travel forks in my opinion.
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Re: best shock for the money
    Quote Originally Posted by sugarsand rider View Post
    Have you looked at suntour's upgrade program? You can get the Epicon with a 15mm ta at just below 4 pounds for $250.
    Apr 2013
    i was really hoping to go with a air spung set up. I think that it will offer a lot more tuneing options
  1. Best V-brake compatible Shock for the money
    By brewbum in forum Shocks and Suspension
    Last Post: 07-08-2014, 04:11 PM
  2. If you had the money
    By jazzanova in forum Bike and Frame discussion
    Last Post: 11-01-2011, 12:55 PM
  3. $$Money$$
    By Skookum in forum Washington
    Last Post: 09-05-2011, 10:51 AM
  4. For the money. what is better IYO
    By davis119 in forum Bike and Frame discussion
    Last Post: 07-18-2011, 09:27 AM
  5. Do you have too much Money?
    By highdelll in forum General Discussion
    Last Post: 03-08-2011, 09:25 PM
