    dog's best friend
    Anyone have some Lyrik 1 1/8 uppers they would like to part with?
    I'm looking for some 170mm uppers for a rebuild. Need 8 1/2" or more of steerer and don't necessarily need the internals. Whatcha got?
    www.derbyrims.com
    Reputation: derby's Avatar
    FYI. When I research this, I was informed the 160 uppers are the same stanchion reach as 170 travel Lyrics. So that means any year upper 1 1/8" steerer will fit your 170 lowers and internals.
    undercover brother
    Reputation: tangaroo's Avatar
    bump. I'm also looking for a set - tapered or straight. Mine are scratched and knicked to hell.
    Reputation: trailbildr's Avatar
    Dec 2004
    $325 new. There are some available if you guys want them. Tapered and straight. 2010 to 2013 part numbers. Here's all the CSU choices:
    CSU, U-Turn, Black Crown, AL Steerer 1 1/8 - Lyrik
    CSU, Coil/Solo Air, White Crown, AL Steerer 1 1/8 - Lyrik
    CSU Lyrik Solo Air/Coil 1/18 Black
    CSU Lyrik Solo Air/Coil 1/18 Diffusion Black
    CSU, 2-Step/Dual Position Air, White Crown, AL Steerer 1 1/8 - Lyrik
    CSU, 2-Step/Dual Position Air, Gloss Black Crown, AL Steerer 1 1/8 - Lyrik
    CSU Lyrik Dual Position Air 1/18 Diffusion Black
    CSU, U-Turn, Black Crown, AL Steerer Tapered - Lyrik
    CSU, Coil/Solo Air, White Crown, AL Steerer Tapered - Lyrik
    CSU Lyrik Solo Air/Coil Taper Black
    CSU Lyrik Solo Air/Coil 11/4 Taper T2 Black
    CSU, 2-Step/Dual Position Air, White Crown, AL Steerer Tapered - Lyrik
    CSU Black Crown AL Steerer Tapered - Lyrik 2-Step/Dual Position Air 180
    CSU, 2-Step/Dual Position Air, Gloss Black Crown, AL Steerer Tapered - Lyrik
    CSU Lyrik Dual Position Air Taper Diffusion Black
    CSU Lyrik Solo Air/Coil Taper Diffusion Black
    mk
    trailwerkssuspension.com
  1. Replies: 3
    Last Post: 07-04-2011, 02:25 AM
  2. Replies: 1
    Last Post: 07-03-2011, 07:58 PM
  3. Replies: 2
    Last Post: 04-14-2011, 05:59 PM
  4. Lyrik uppers on the wrong way around
    By JBone in forum Shocks and Suspension
    Last Post: 02-27-2011, 05:56 AM
  5. RS lyrik Problem uppers squeaking??
    By stefikj in forum Shocks and Suspension
    Last Post: 02-07-2011, 05:04 AM
