Results 1 to 9 of 9
    Reputation: woodyak's Avatar
    Anybody know if the 2014 RS Pike 160 can be lowered?
    Can't find any info anywhere on it. I cracked her open and tried a spacer but that didn't work.
    Just found out from my LBS that it cannot be lowered w/o replacing the air sleeve. Doh!
    Reputation: Fix the Spade's Avatar
    Oh well, you'll just have to go a bit fast and use the extra travel.
    Oct 2010
    Quote Originally Posted by woodyak View Post
    Are different length air sleeves available? 140mm?
    Huh? You can't slip in spacers under the air piston, and on top of the topout spring like most air forks...ie) Revelations...?
    Quote Originally Posted by Imagesforsegways View Post
    150 will be available as they sell it as an option. Not sure about the 140. Kinda doubt it.
    Quote Originally Posted by Pau11y View Post
    Nope. I had the thing apart and it's different than the Rev. No place to put the spacer. I had my LBS contact RS and they confirmed that you need to replace the entire airshaft to shorten it. Unfortunately parts won't be available for a bit.
    Yeah I got a pike at my LBS a week ago and they said it wasn't supported. I was trying to decide between a 160 and 150. They both have both sag guides on the stanchions so its kind of weird that its not easy to switch travel. Oh well it's a great fork anyway.
    You didn't happen to have shot some pics did you...? Or actually, maybe some exploded engineering dwgs?
  1. Pike 2014
    By redranger in forum Shocks and Suspension
    Last Post: 1 Week Ago, 02:32 PM
  2. Can the new Pike 160 650b fork be internally lowered to 150?
    By mastakilla in forum Shocks and Suspension
    Last Post: 05-16-2015, 08:16 AM
  3. 2014 RS Pike. Anyone get one yet?
    By woodyak in forum All Mountain
    Last Post: 10-14-2013, 04:35 AM
  4. Pike 2014 : End0 versus Chilly
    By gautama108 in forum Knolly
    Last Post: 06-27-2013, 04:58 AM
  5. 2014 Pike Availability
    By Dazed in forum Shocks and Suspension
    Last Post: 05-10-2013, 06:24 AM
