    Another "What fork to get." need replacement for an indy XC.
    I just got a new to me 97 Gary Fisher HKEK that has been gently used, except the paint. I wanted a steel frame, so with my budget, old it had to be.
    I am not interested in tossing the bike for a new one (this is my new one!), as many have offered in similar threads and for now the fork on it is in great shape for what it is, the elastomer looks new, not stained, torn, split bloated, etc. Its my first bike after 18 yrs of riding with no suspension, in fact first time I have ever tried. My old bike was an 88 Fisher HKEK if that tells you anything.
    The fork has a 67mm travel and it looks like it came available with a 80mm kit and I realize that the geometry might be a bit off, but what forks would you all recommend for a replacement. 1 1/8 " tube luckily.
    An 80 mm would only add 13mm or 1/2" in front end height, changing the wheel axle distance by "?"
    Is this geometry failure or just up to me.
    So far the usual recommendations are the Dart variations, what else?
    I am riding singletrack trails with lots of big roots and rocks, but pretty loose and few drops.
    I would also like to get one that can be locked out, if that helps.
    Former Bike Wrench
    Thanks,
    I noticed that fork's "drop outs"(?) are forward of the tubes, adding perhaps another inch forward as my old Indy's are straight. Is this getting things too out of whack geometrically? Otherwise it looks like a very adjustable fork.
    Former Bike Wrench
    Quote Originally Posted by trythis View Post
    Thanks,
    No, the rake will be similar. The Indy simply had its legs slanted forward more to put the drop outs in a similar position.
    The Minute is so much more fork than an Indy you won't believe what your bike can suddenly do
  1. Dart better than 13-year-old Indy S fork?
    By M-80 Rider in forum Shocks and Suspension
    Last Post: 06-14-2011, 09:57 PM
  2. Rigid fork advice for Indy Fab
    By x-wing fighter in forum 29er Bikes
    Last Post: 10-25-2008, 06:43 AM
  3. Need help choosing a fork for Indy Fab frame
    By dirty_garage in forum Singlespeed
    Last Post: 05-08-2008, 10:08 AM
  4. Indy C Replacement
    By Lil' monkey in forum Shocks and Suspension
    Last Post: 01-13-2008, 07:33 PM
  5. Indy Fab Steel Fork Pricing
    By Ranger Pride in forum Custom Builders & Other Manufacturers
    Last Post: 06-20-2007, 09:29 AM
