Results 1 to 2 of 2
    inner peace to make peace
    Reputation: TrailNut's Avatar
    New question here. AM hub, fork, and wheel build?
    Looking ahead, i am planning to build a 2nd front wheel for AM riding, esp. for steep & rocky descends. My current wheel's old, over a decade, and I have noticed that the 9MM_QR fork of the 2004 Marzocch Z1 FR ETA 130MM (5.5#s) does flex at my weight, 230#, while descending on my steel hardtail.
    Is there front disc hub(s) that can be used for 15MM QR, but later be fitted with a 20MM TA?
    Should I just skip the 15MM and go to a 20MM TA?
    I want a sturdy and reliable fork in the 100MM to 120MM range, or a 130MM to 140MM range if the fork has on-the-fly travel reducer. I'd like coil, if I can find it.
    Please recommend disc hub & fork and a rim that'll handle 2.5" 26er tire. I use a 200MM disc, Formula Oro Puro.
    “Everyday is a good day,” from the Blue Cliff Records, Yun-men (864-949 AD).
    Future proof your front hub and buy a hub that offers conversion end caps / axles. There are plenty on the market ie. Hope, CK, Hadley, DT Swiss and many mid level hubs. I run a Stan's 3.30 that does QR, 15 & 20mm.
