Results 1 to 6 of 6
    Oct 2012
    air = between forks?
    Hi, new to MTB but come from a long line of Motorcycle use and repair.
    I am getting ready to put together an FS Fatbike but was wondering which is the best way to go with Forks.
    I have never had a pair of modern MTB Air forks apart so not sure how the air = between the two legs..
    On a cycle rig you use an equilizer hose or accurate pressure gauge.
    Do the forks for MTB have a way to equilize pressure between the forks or is it just a single fork system for the air part?
    There is just one side that has compressed air. The other side has the damper.
    Jan 2013
    Do both sides have oil in them or just the damper side?
    Quote Originally Posted by Placibo View Post
    Most modern forks separate the damper oil from the bushing / seal lubrication fluid unlike a motorcycle that uses the same oil for both functions. Most air springs are lubed w/ grease or a small amount of oil.
    Oct 2012
    Thanks for posting up answers.. It clears up any misconceptions I was having.
    Oct 2011
    Quote Originally Posted by jennifer012904 View Post
    I don't know which model of the fork you have but every manufacturer has a lot of info, detailed 3D images of fork parts, service manuals etc. on their website so you can look there for more specific information on how to service/maintain/modificate your fork.
