Results 1 to 5 of 5
    Adjusting travel on 2013 Sid RCT3 29"
    Hey, I've searched but can't find a straight answer. Just wondering if it is possible to change the travel from 100mm to 80mm with Rockshox spacers on the 2013 Sid RCT3 forks? Has anyone tried, and if not, is there a way to acheive the travel reduction?
    Thanks.
    Nope. The 2013 Rockshox no longer use travel spacers. You'll need to replace the air spring assembly if you'd like to adjust travel. I'm not sure how much they'll charge for the new solo air assembly, but in the past these ran about $70.
    B A N N E D
    Hahaha, when i first saw that link i was all , i've googled the crap out of this and can't find a straight answer. But then i was all Thanks so much!
    Shame it's not as simple as a spacer anymore, but I'm glad it's still possible.
    Thanks lads!
