FAT BIKES
WINTER APPAREL
TRAINERS
Page 2 of 2 FirstFirst 1 2
Results 26 to 50 of 50
  1. #26
    inexperienced at large
    I hope other people have extra Monarch shocks sitting around.
  2. #27
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    Quote Originally Posted by ehigh View Post
    These guys seem to:
    Rock Shox Monarch 4.2 - No Hardware 2010 | Buy Online | ChainReactionCycles.com
    Magura
  3. #28
    Ones that don't cost money, that is.
  4. #29
    DIY all the way
    Aug 2010
    Well, worst case, it can easily be reversed, so no big deal to do it to a shock in use.
    Magura
  5. #30
    Of course, but in my case I have an extra I'd be willing to sacrifice for worthy experiments.
  6. #31
    DIY all the way
    Aug 2010
    I just ordered parts for the next step.
    I want preset ride heights, and I want them adjustable, so this is going to be electronics.
    I figured to have a couple of adjustable presets would do.
    What do you think about that?
    Magura
  7. #32
    moaaar shimz
    Reputation: tacubaya's Avatar
    Mr. Magura,
    What is the purpose of compressing the shock? This would decrease seat angle and decrease head angle, thinks that do not improve climbing comfort and performance.
  8. #33
    DIY all the way
    Aug 2010
    Quote Originally Posted by tacubaya View Post
    Mr. Magura,
    A lower center of gravity would be one reason.
    Another reason is for situations where 160mm travel is not doing any good, like gravel roads and smooth single track, hard pedaling, etc.
    Sprinting could also be improved (not that I do that kind of stuff).
    Magura
  9. #34
    Save Jesus
    Reputation: beanbag's Avatar
    Quote Originally Posted by Mr.Magura View Post
    With an electric valve, allowing to move air from one side of the air piston to the other.
    By moving air out of the positive chamber, won't that make the spring rate too soft in the "lowered" position? Perhaps you could move oil instead?
  10. #35
    DIY all the way
    Aug 2010
    Quote Originally Posted by beanbag View Post
    That depends how it's controlled.
    How do you suggest to do it with oil?
    Magura
  11. #36
    Save Jesus
    Oil would flow into the negative chamber, and with the small amount of air still in there, would provide a soft hydrolock that limits extension - same as if the shock were shorter in the first place. You could also have a floating piston between the + air and this oil volume, depending on if you wanted the + side to get softer anyway.
  12. #37
    Sep 2012
    Well, my point in this, was rather to be able to lower and stiffen up the rear for climbing and gravel roads, as opposed to Fox just stiffening up the rear, but still leaving the rider hanging 100mm too high to be ideal for the situation.
    I think I will attempt something similar for my Revelation. It could be rather neat to lower the bike like 100mm in both ends.
    This mod is relatively simple to do on the Monarch, but I still haven't figured the solution for the Revelation.
    Magura
    Is the revelation Single or Dual Air?
    If its dual air, I think it is an easy mod. I should try this....
    -S
  13. #38
    Sep 2012
    Don't quite like those 2010's, especially the air inlet... feels like it's going to break off any time. LOL.
    -S
  14. #39
    DIY all the way
    Aug 2010
    Quote Originally Posted by shibiwan View Post
    -S
    It's dual air, but I can't seem to find room for the valve.
    Magura
  15. #40
    DIY all the way
    Aug 2010
    Hmm, that's worth some thought if it turns out to be an issue. It will make the system a lot more complicated though, and add like 80 grams to it.
    Magura
  16. #41
    Sep 2012
    Magura
    Probably needs to go on top, at the crown where the current schrader valve is.
    -S
  17. #42
    Sep 2012
    Maybe its a good thing.... a pushbutton "plush" setting too.
    -S
  18. #43
    DIY all the way
    Aug 2010
    -S
    ....and that my friend, is where trouble starts
    It needs to cross the piston somehow, which is not happening from the outside, as far as I am able to figure it right now.
    Magura
  19. #44
    DIY all the way
    Aug 2010
    -S
    It depends how it's operated. If it's loaded during the shift, and the flow is cut off fast enough by the valve, things are not changing much.
    The valve I used is extremely fast, so I just need to make sure the electronics behind don't slow things down, which means using fast sensors.
    Magura
  20. #45
    Sep 2012
    Magura
    Why not? Run a long poly hose from the bottom schrader to the top valve assembly...
    It'll definitely cross the piston and "connect" the bypass between the two air chambers... or am I missing something?
    -S
  21. #46
    DIY all the way
    Aug 2010
    -S
    You might be on to something. If there is room in the piston for it, it could fly.
    The top cap will need some nifty solution though for this, but that's a minor detail.
    Another thing that needs to be tested, is if the magnet for the switch, can activate the switch through both the inner and outer leg. Else the electronic control is going to be hard to sort.
    Magura
  22. #47
    Sep 2012
    Magura
    Don't even need to go into the air spring or muck with the piston ... just bridge the two chambers with the bypass and put the electronic valve in-line with the bypass tube.
    At some point I'd be looking into modding the damper to use magnetorheological fluids...
    -S
  23. #48
    DIY all the way
    Aug 2010
    -S
    I'm not sure I follow your train of thought here??
    Magnetorheological fluids have been on my ToDo list for a while.
    Trouble is the power consumption.....
    I have some future plan to test high frequency pulsed PSU's in that application.
    By now there are some pretty advanced, high efficiency, LED driver chips out there from Onsemi, that seems to fit the bill.
    Magura
  24. #49
    Save Jesus
    And the weight
    And the abrasion
    And the lousy damping characteristics
    And getting sued by the Lord Corporation
    Not that that's a dis-incentive or anything...
  25. #50
    DIY all the way
    Aug 2010
    And the weight
    And the abrasion
    I guess you got a point
    Magura
Follow MTBR on Facebook
