Adding a remote to a Fox CTD shock
I just picked up a frame that comes with a Fox Float CTD Evolution Rear Shock. I see that Fox offers a remote for the CTD function. It looks like my fork does not have the connection for the remote, but could I add it? I've looked all over the internet and I'm not finding anything close to a solid answer.
I'm guessing it's not possible, but I thought I'd ask.
I asked the same question and someone on here said no. Don't know why they wouldn't make this possible. I would definitely pay to upgrade it. Kinda sucks actually.
Just asked at a Trek Dealer to put a remote on my Fuel EX7 and its only possible in the FOX FORK and in the REAR SHOX that already have the connections from factory.
Sent from my iPhone
That's kinda what I thought.
Have you tried calling Fox directly? Im sure someone in their tech or sales dept could help you with the answer. I do know that the little blue selector switch is removable so it may be possible to get the piece needed for converting it. I think its worth a shot at calling if its something you really want to do. Food for thought.
Picking up the phone and making a personal one on one connection with a live person...I don't understand
I'll give them a shout on Monday, after the holiday.
First of all you can only do so much with remote, mostly lock out. RS has one that you can adj compression, and lock out, Magura has one that adj travel which is pretty simple actually. Except for Magura none has work properly for me in the long run. I don't think it's worth the trouble.
Sent from my iPhone 4s using Tapatalk
There is a conversion kit for front CTD shocks, but not for a rear shock unfortunately.
My post count is too low to post a link, but maybe this will get through
service.foxracingshox.com/consumers/Content/Service/QuickTech/CTD_Remote_conversion_proc.htm
Fox sells a remote kit. If you've got a 2013 CTD trail adjust Float I'd be interested in talking. I have a 2013 CTD remote that I'd like to convert away from the remote.
Does anyone knows if this 2013 CTD remote will work on a 2012 Fox EVO 32 with CTD?
Sent from my iPad
I'll get the model number when my frame arrives on Monday. I'll keep you posted.
Does the remote spring back on it's own or does the lever have the return spring in it. I took out the blue knob and may make my own. I want to use the old style remote lever as I only want to switch between Climb and Trail...will never use the descend. I have a machine shop available so I think it will be easy to do. Drawing up plans tomorrow.
Obviously there is no original conversion kit for rear shocks:
mojostore.co.uk/acatalog/CTD-Remote-Kit.html
But maybe you can find some homebrewed solution like this one:
youtube.com/watch?v=KL30jdx2gsc
I wanna try one such in this video but a bit nicer on my Float CTD Evo
FWIW, I just got my Fox CTD Evolution back from Fox. They were able to swap out the top cap on the shock to fit a remote topcap on and supplied me with the dual remote which has all of the parts to convert the fork. I had a few other things done, but my total was $290- The remote kit alone (with parts for the fork) is $80 (not bad, really), and I think I had about $80-90 of other work done... so $200 and it CAN be done.
"There are two kinds of mountain bikers in the world: those who are faster than me, and me."
Hmmm. This is annoying. I didn't realize the rear shocks cannot be converted unless they are a certain shock. I also didn't realize that there is the Evolution/Performance and then the Factory with the three trail settings.
Did you inquire whether they could have also added the 3 Factory trail settings to your Evolution fork?
My Giant AX1 29'er came with an Evolution CTD rear shock. Is this shock tuned to my frame? If I wanted to upgrade to the Factory CTD remote shock is there a version that is tuned for my frame?
Best thing to do is call Fox and try to talk to Ed in service. He's the service manager and runs the show. Great guy to deal with.
Here's my understanding:
1. Yes, your shock is tuned to your bike- meaning that Giant asked for the Compression to be tuned a certain way, and the Climb mode to be tuned a certain way. If you look at the bottom of your shock, there should be a sticker band around the bottom and it should say Compression tuned F, M or S (Firm, Medium, Soft) and the same thing for Climb. My Climb mode on a 2013 Stumpjumper FSR came Medium, but I had it changed to Firm as it still had too much bob in "Climb" mode (for me).
2. My understanding of the 3 factory trail settings is that, yes, they could've changed that, however, when you put a remote on the shock, you lose that anyway (even if you had a "Factory" level shock).
Hope that helps.
Hope that helps.
Cool, fair enough. Thanks for the excellent feedback. I am the most pissed about the rear shock. The fact that you can't even modify it to allow for a remote is un-acceptable. That is engineered exclusion and ridiculous. I guess I am used to having the higher end RP 23 and RLC 32 on my previous bike. I also miss the lockout adjustment on the RLC 32 fork and the compression dampening adjustment.
Pure curiosity, I wonder... if you are able to convert the Evo CTD to remote, can you convert it to Trail Adjust? May not be worth it to pay Fox to do it, but I just wonder if it's physically possible to do to an EVO CTD fork. Since you can't change the non remote Evolution shock to remote, I bet it's not possible to add the 3 Trail Adjust knob to the Evolution shock either, but perhaps I'll ask about that too.
EDIT. I asked and Fox answered. You cannot add Trail adjust to the fork or shock. Different dampers.
I hadn't noticed this, but for 6.5" shocks, like the one for my Giant AX1 29, the only difference between the Evolution and the Factory CTD shocks is the Kashima coating and the fact that you can get a remote version. There is no 6.5" version with the 3 settings of Trail adjust.
- You may not post replies
- You may not edit your posts
Forum Rules
