Results 1 to 3 of 3
    Jul 2013
    97 RockShox Judy XLC replacement
    Sorry if this is too ancient of a question, but I have a 97 Trek Y-Glide with RockShox Judy XLC dual crown forks. As old as these forks are they have worked well but have finally given out and they are to old to get repaired.
    What would be a good replacement for these Judy XLC?
    They are full coil set up and I have always liked the ride.
    I weigh 280lbs so Air shocks I have tested out don't really hold me as well, lol.
    Any and All suggestions would be welcome.
    I'm guessing that if you're talking about replacing a fork from 1997, that'll you'll need v-brake mounts and relatively short travel (by current standards). I would recommend either a Rockshox Recon Silver Coil or Manitou Match. They're not dual crown, but have 32mm legs that should be plenty stiff. Usually, they with come 100mm of suspension, but you should be able to change the spring (which you'll want to do anyway to get the x-firm spring) for a 80mm spring to reduce the travel if you need it. The experts will tell you that the Manitou has a better damping system. I've got the Recon and it seems fine to me. Guess I'm not that picky.
    2004 Surly Cross Check
    2008 Surly Long Haul Trucker
    2011 On One Inbred
    Jul 2013
    Thanks for the reply, good tips.
    Bike is old just want to keep it going minimally, ordered XC28 and x-firm springs, perfect for the budget.
  1. Rebuilding a Rockshox Judy XC
    By manoian in forum Shocks and Suspension
    Last Post: 09-04-2013, 07:02 AM
  2. Rockshox Judy T2 - "plunger bolt" replacement? needed?
    By FatMcPhat in forum Shocks and Suspension
    Last Post: 05-04-2013, 05:32 PM
  3. Rockshox Judy J1 Leaking
    By azorr in forum Shocks and Suspension
    Last Post: 09-16-2012, 05:25 AM
  4. Improving 06 RockShox Judy
    By MaddSquirrel in forum Shocks and Suspension
    Last Post: 08-10-2011, 12:31 PM
  5. Replace a Rockshox Judy xc
    By St.Zu in forum Shocks and Suspension
    Last Post: 01-13-2011, 09:16 AM
