My brother gave me an old '97 Gary Fisher Paragon with the Indy SL fork. Fork is shot, took it apart today, the elastomer crumbled out. I have two questions.
First, how do i separate the lower from the upper fork? I found a manual online. It says to loosen bolt with a 6mm hex head. I stick it down in there but its not engaging anything, i look down in there with a flashlight and cant see a hex head.
Second, should i just replace the fork? If so with what? the indy sl is 1 1/8" threadless, 63mm travel, I would want something i could just swap right in. Or should i buy some elastomers i found for $53?
What would you suggest? I dont want to spend a lot. This bike wont get ridden much, i just want it operational. Rock shox XC28 is very cheap, would this work for light trail riding?
Yes a XC28 will "work" for light trial riding. I hope really cheap is a lot less than a $100.
If by "light trail riding" you mean smooth gravel paths. Then you might be able to find a really really cheap Suntour XCR fork, second hand that someone has taken off there bike. These forks get a lot of negative feedback. For the intended purpose (light trail riding) they will be better than the original old Indy fork.
I would only use a Suntour XCR or above model fork.
This thread might help. You can get poly urethane rod off Amazon that might let you rebuild the Indy fork.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
