Results 1 to 12 of 12
    Reputation: mrjustin007's Avatar
    96 Judy XC & 96 Judy SL Lowers
    I have a Judy XC that is 1 1/8 steer, and a Judy SL 1" steer. The SL is blown, can I swap the XC lowers over?
    WTB: Bontrager Comp Fork & Syncros metal top cap
    Former Bike Wrench
    Yes, the lowers are the same (other than color...even then there were some yellow XC's in '96)
    But swapping the lowers isn't going to fix a blown damper
    The XC works fine, I just need the 1" steer.
    Former Bike Wrench
    You can swap the Crown...just unbolt it from the stanchion tubes (1996 was still bolt on)
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Just so you know, you can also cut a SID from it's crown and it will slide right into your pinch bolt Judy crown.
    bonked
    Reputation: IF52's Avatar
    SID guts, Judy crown, late 90s Judy lower
    And it will look like this
    Quote Originally Posted by banks
    That is one big f'n dude!
    Yes I am!
    Former Bike Wrench
    And what appears to be Scott-Peterson (Suntour) self energizing brakes?
    bonked
    Critical Racing. I have since replaced them with M900 XTR though.
    Yes I am!
    Former Bike Wrench
    Ah yes, I was fooled by the lack of green or purple anodizing ;-)
    I've been contemplating the SID solution, but don't want to spend the $$ - the fork is on an older 1" bike that I want to get running for as cheap as possible. The Judy SL does not have the bolt on crown, so it may not be a 96
    Former Bike Wrench
    Arg....you just rattled my brain and knocked some cobwebs away
    The 1996 SL did not have a bolt on crown as a weight savings...I remember now
    I do believe however that you could gut your XC and put the parts into your SL with the 1" steerer
    bonked
    Quote Originally Posted by mtnbiker72
    Yes. Gut away. And keep an eye on eBay for cartridges, they come up every now and then.
    Yes I am!
