Results 1 to 2 of 2
    Dec 2011
    888 RC3 Leaking Fluid From Bottom
    Hey folks,
    My 888 EVO RC3 has leaked quite a bit of fluid out of the bottom, where the compression adjustment nob is. This occurred once when it was just sitting in my garage, and also right after a decent ride. Any idea as to how I should start fixing this? I'm not familiar with working on forks, but am comfortable with all sorts of general bike maint.
    Thank you!
    Try to tighten the nut under the compression adjuster, the big one. Might need somebody to compress the fork as you tighten. If still leaks or the nut is tight the o-ring under the nut is probaly bad.
