Results 1 to 6 of 6
    Jan 2009
    888 rc3 evo v2 titanium
    Hi! I know that this fork has some complicated adjustments.
    What does each knob do?
    I saw the manual but it was not helpful.
    staike
    Reputation: staikeinthahood's Avatar
    They're not complicated at all.
    On top of the right hand stanchion the grey knob is. Turning this in will increase spring preload. It compresses the spring and gives you less sag. Keep in mind that it doesn't make the overall spring any stiffer.
    On top of the left stanchion you have two adjusters. The red one on the top is your rebound adjuster. Turning it in (clockwise) will increase rebound damping and therefore make the fork rebound slower. The silver one below is the VA (Volume adjust). As you might know, air gets "harder" when it compresses. Inside of the fork there is air. Turning the adjuster in (clockwise) will make the room where the air is, smaller. Because of that the fork gets more progressive, which means it gets harder and harder to compress the further you get into the stroke.
    On the bottom of your left leg (the gold knob) is your Low Speed Compression (LSC). There is a total of 9 clicks. Turning in more LSC will mak the fork compress slower on Low Speed hits. Low Speed hits is bobbing from pedaling, brakedive, etc. You probably understand what I mean.
    If you want to adjust High Speed Compression, you can play around with the shimstack inside the left leg. But you shouldn't worry about this, the stock tune works just perfect for most people. HSC is when the fork compresses fast, on drops, square edge rocks, etc.
    I hopw this made you a little bit more confident in playing around with the adjusters. They are there because you're supposed to turn them, so don't be shy regarding trying different setups.
    Jan 2009
    perfect analysis!
    thanks a lot!
    Jan 2009
    a few more questions:
    1.in the specifications it says ''HI LO AUTO COMPRESSION ADJUST''
    what is this?
    2. where is the valve for the air?
    staike
    1. The golden knob. It essentially adjust LSC, but adding more LSC will also affect the blow off point for the HSC. It won't affect the HSCin itself, only the point where it goes from LSC to HSC.
    2. There is no valve for air. Many people confuse the Volume Adjust with air preload. What I meant by saying it's air inside the leg is that it's just that, air. It's no air pressure. But the pressure will increase when the fork compresses.
    See here:
    Jan 2009
    ok, many thanks!
  1. 2012 Marzocchi - 66 RC3 Evo Titanium - 888 RC3 Evo Titanium V2
    By Nick_M2R in forum Downhill - Freeride
    Last Post: 07-05-2012, 08:00 PM
  2. A Titanium 1X9
    By Moto Rider in forum Motobecane
    Last Post: 06-28-2010, 06:15 AM
  3. Replies: 20
    Last Post: 07-18-2009, 12:35 AM
  4. Titanium headset in Titanium frame? (galling)
    By SurfHenk in forum General Discussion
    Last Post: 04-07-2009, 08:23 PM
