8" rotor for MX Pro?
Printable View
  • 02-22-2007
    No MSG
    I just ordered the Marzocchi MX Pro ETA/TAS from 2006. The online manual specs it for a 6" rotor. I ride a very hilly area, but won't be bombing downhill. I will probably ride for a half-hour downhill on fire roads. My current brakes are Deore hydros modified with 8" Gothic rotors both front and rear. For my use, is there any significant danger in running 8" rotors despite what Marzocchi says?
  • 02-23-2007
    stretch169
    I run the 185mm front rotor with my BB7 on my MX Pro ETA no problem.
  • 02-23-2007
    medshed
    I used Hope Mono M4s with an 8" rotor on my 2005 MX Pro ETAs. Never gave me any bother and I used them in the alps on long descents (7 miles).
  • 02-23-2007
    crisillo
    I have used a 180mm and a 185mm on my old MX and Marathon.... but it already showed some visible flex (stopping my 220 lbs :) )... a 203mm rotor would be too much and is definitely way over Marz specs.... the 07 MX forks are apparently clear for 180mm, stanchions are still 30mm,l maybe3 they modified the dropouts a bit (or just decided to allow it now)
  • 02-23-2007
    demo_slug
    I broke the brake tab on my 2005 mx pro with 203mm brakes. fixed it with super glue and sold it. :)
  • 02-24-2007
    Call_me_Clyde
    That's not funny
    Not even close to being funny. You should be strung up for the mere fact that you did this.
  • 02-24-2007
    Jerk_Chicken
    Correct, the lowers were different for 2006.
    As far as that superglue on the broken tab, really not funny. Should be a temp ban, if anything.
