Results 1 to 9 of 9
    Dec 2008
    2018 Revelation judder on braking
    Hi
    When braking slightly i'm getting a slight judder through the fork, is this normal on a RS fork or could it be brake induced?
    Cheers
    It's your brakes. Either they aren't aligned or you have spooge on the rotors.
    Reputation: 11053's Avatar
    check your headset.
    loose headset can also be the source of that issue.
    Reputation: flipnidaho's Avatar
    If your headset is tight, also check the fork's bushings.
    Reputation: trailbildr's Avatar
    Dec 2004
    It's just a flexy fork. It happens quite a bit on those 32mm forks. Totally normal. I had a few Revs over the years and to some extent they all did this. You can change brake pads, check headset, all kinds of stuff but there is some deflection-based resonance regardless of what you do. Stiffer forks exhibit this trait a bit less.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    May 2015
    Quote Originally Posted by trailbildr View Post
    2018 revs are 35mm. Same chassis as pikes.
    Dec 2008
    Cheers - already checked the Headset tightness.
    Dec 2004
    I missed the 2018 in the subject... Some resonance is normal.
    mk
    TrailWerks Cyclery
    Dec 2008
    Cheers, it is also more noticeable when the brake pads are cold.
  1. Replies: 4
    Last Post: 06-14-2018, 10:20 PM
  2. Replies: 5
    Last Post: 05-24-2018, 04:19 AM
  3. 2018 Pike OR 2018 Push Fox 34 Factory?
    By almazing in forum Shocks and Suspension
    Last Post: 01-25-2018, 12:35 PM
  4. Fatbike braking -vs- skinny tire braking
    By mabrodis in forum Fat bikes
    Last Post: 12-11-2017, 12:36 PM
  5. 2018 Nomad vs 2018 V10
    By cobrakillerta in forum Santa Cruz
    Last Post: 10-04-2017, 06:26 PM
