Results 1 to 3 of 3
    Jan 2011
    2014 RS Pike Rotor Size
    I have searched and have not found the info I need. So, is the new Pike fork set up to run a minimum rotor size of 180mm or 160mm? I am getting a Pike 140mm travel 51mm offset, 29er and need to know if I will need an adapter or not as the fork I am replacing is direct mount for a 180mm rotor set up.
    Reputation: jjkitt's Avatar
    The Pike's PM is for 160mm...you'll need an adaptor for 180mm.
    Hope this helps.
    Cheers,
    "I Like the Cut of His Jib"
    Jan 2011
    That's what I needed to know, Thanks.
  1. Pike 2014
    By redranger in forum Shocks and Suspension
    Last Post: 01-09-2018, 08:10 AM
  2. Rotor size on 2014 Superfly 9.8 SL?
    By thomasshawn in forum 29er Components
    Last Post: 01-21-2014, 08:26 AM
  3. 2014 RS Pike. Anyone get one yet?
    By woodyak in forum All Mountain
    Last Post: 10-14-2013, 04:35 AM
  4. 2014 Pike Availability
    By Dazed in forum Shocks and Suspension
    Last Post: 05-10-2013, 06:24 AM
  5. Pike Rotor Size
    By J_R_A in forum Brake Time
    Last Post: 02-13-2012, 08:35 PM
