2013 Rockshox SID XX Solo Air adjustments/fitting
Got my bike home after having this shock installed and can't find how to adjust to my weight or what to actually adjust. Unless I've missed it, it's not even on their website. How do I fit this fork to me?
It's only got a pos air chamber filled through the schrader valve on the top left fork leg. There will be a cap you screw off first and underneath that is the valve. Set the fork up with whatever pressure will give you 20-25% sag and tweak from there.
And setting up rebound on the bottom? What's best way to do that?
Start with rebound in the fastest setting and the lockout off. Find a good, smooth fast corner you're comfortable attacking repeatedly. Keep adding more rebound damping until the bike feels nicely settled mid corner and through the corner exit. If you've got too little rebound damping the bike will want to push wide on exit, if you have too much then the bike will feel like it wants to "knife-in". If in doubt, too fast rebound damping is always better than too slow.
How many clicks of rebound someone else is using will not be applicable to someone else, so pretty much ignore anyone who suggest a certain number of clicks as a great rebound setup. The SID rebound adjuster is not accurate from fork to fork and how much rebound damping you need is entirely dependent on how you ride (how much weight on the bars, how you smoothly you transfer that weight on braking, how hard or smooth you apply the brakes, how smoothly you stop applying the brakes, how much you use your arms to absorb bumps etc.).
If you change your pos air pressure then you may need to re-adjust your rebound to suit (typically more damping with higher pos air pressure).
Huge help. Thank you. I'm about 210-215 and put the pressure at 135lbs. Seems like a lot. Is the guide on the fork not super accurate?
Those guides are very rough. If you set the pressure by the desired sag % then you can't go wrong.
It's a 120mm fork. There won't be 120mm sag gradients on a 80/100mm version. You need to either return it or buy a new 100mm air rod. On the older pre 2013 models you would just add in a couple of 10mm all-travel spacers.
Are you sure? Can anyone with the 2013 100mm version confirm if the sag chart printed only show 80 and 120?
I can't be sure. What you need to do is download the SRAM 2013 parts catalog and take a look in there for part numbers. See if there is a difference between part numbers for 80/100 and 120mm 2013 uppers. If there is then you have your answer. Otherwise, just pull the fork apart and measure.
- You may not post replies
- You may not edit your posts
Forum Rules
