Results 1 to 2 of 2
    Reputation: MarkerMan's Avatar
    2013 RockShox Sid RCT 3 Setup Help
    Just installed the 29er 100mm version, but can't any instruction for setting up the fork. The SRAM website is worthless.
    All I can find is info on the dual air version but mine is single air.
    Any help would be appreciated.
    Reputation: Kiwiplague's Avatar
    Single air versions basically requires you to set the correct air pressure for your ride i.e. 20% sag.
    The RCT dial has three positions, open, threshold and locked. The LSC dial will have an affect on all 3 positions. You can run the fork in threshold mode with about 2-3 clicks of LSC, and the fork will stay firm on pedalling etc, but will react to most bumps very easily.
    I don't crash, I just have slightly uncontrolled dismounts!
  1. rockshox fork guidelines off for sag setup
    By kneetowaist in forum All Mountain
    Last Post: 10-20-2017, 01:02 PM
  2. 2013 Fox Float 29 CTD or 2013 Rockshox SID XX
    By ddublu in forum Shocks and Suspension
    Last Post: 12-26-2013, 12:44 AM
  3. RockShox Ario Users - Whats your setup
    By mbogosia in forum Motobecane
    Last Post: 02-23-2012, 10:02 PM
  4. Rockshox revelation rlt 140 2011 setup
    By Dawbs96 in forum General Discussion
    Last Post: 02-11-2012, 08:24 AM
  5. Rockshox Vivid Air R2C - Setup & Questions
    By rideitall in forum Shocks and Suspension
    Last Post: 11-01-2011, 08:53 PM
