Results 1 to 56 of 56
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    New question here. 2013 Fox CTD fork set up?
    2 rides with my new 2013 Fox 34 Float 29 140 Fit CTD and I'm not that thrilled.
    The "Trail" setting seems to lose the small bump sensitivity I'm used to with my old Talas 32 (I have a couple of them).
    The "Decent" setting with the medium range seem okay for the portion of the ride I was using it.
    With "Climb", "Trail" & "Descent" mode, and a "soft", unlabeled/middle & "firm" settings, has anyone seen a matrix or list of what is actually happening?
    Does the "Trail Adjust" do anything in the Descent & Climb mode?
    The shiny 77 page manual (11 in English) that came with the fork & shock don't cover CTD at all. The LBS can't help as this is the first one he has sold (the fork came with a complete bike).
    Checking the Fox site doesn't show any sort of tuning guide for the CTD forks. (There is some marketing stuff that covers Fit, Kashima & 15QR.)
    There is a little CTD marketing info here:
    CTD Explained | New for 2013 | Bike | FOX
    What settings are people running?
    Help please.
    If anyone is curious how these things work, here is PB's take on it:
    2013 FOX Suspension CTD Damper - First Ride - Pinkbike
    Chilling out
    Reputation: bear's Avatar
    I've only 30 miles on mine so far (got it Sat on board my new Yeti) and I sure don't hate it.
    From what I've read, and playing with on the trail backs this up
    - "trail adjust" has no effect in Climb or Descend mode, they are fixed-settings
    To set mine up I applied what I thought was a little common sense and did the following..
    - Set it to Descend mode, set rebound all the way out/off/fast
    - Set static sag
    - Set trail-tune in middle
    - Set to Trail mode (as I was going to be riding a bunch of ups n downs n rocks n stuff)
    I proceeded to go for a 16 mile ride (at Moosic Mtn Conservancy near Scranton PA, if anyone cares to know).
    There was one notable drop that I hit all afternoon, just shy over 2' to a flat rock landing.
    By the end of the day I'd used all but about 1/4" of travel on the fork, so I dropped JUST A FEW psi out.
    disclaimer: I haven't seen a tear-down or such by someone tearing into the damper to see what's what. This is all by feel.
    Probably tainted quite a bit by New Bike Honeymoon Phase.
    One of the members on NSMB pointed out that there is a 2013 manual available on the Fox site here:
    WebHelp
    But there isn't any more info on the CTD than in the marketing info on the other page.
    Time for me to eat some crow, the set up info is on their site, just burried 3 folders deep in their Java based help site I linked above.
    34 FLOAT 29
    Now at least I have a set up guide to use & explains what is going on in each mode.
    More than 48 hours and no reply from their CS.
    Never did receive a response from them, disappointing.
    The moral of the story is RTFM (if you can find one...)
    The starting set up detailed in the owners manual linked above is very close to what I like. I didn't have enough air in the spring & to much rebound (I'd set is 1/2 way in, the set up guide has 1/3rd.)
    Chilling out
    The fox manual surprises - my psi is definitely close - I need to compare rebound setting just to see where it has landed if for no other reason.
    Fork works great though! Faintly wish I has the '13 CTD rear damper to match.
    Sent from my brain using neurons fueled by caffeine
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    You're right though, this setup stuff should come with. Or at least quicker to access, that site reminds me of OS9. The booklets they've been sending called "owner's manual", kind of generic nothingness and a waste of paper
    I would think a 2' foot drop to flat, you shouldn't be using more than half your travel or so.
    Chilling out
    Depends on how well or badly you land. ;^)
    There were other moderate/high speed chunk in the ride that probably accounted for more of the travel use.
    I definitely used it up more aggressively without any real air time at all just this past weekend at Bald Eagle forest ... longer & faster downhill runs with significant rock fields and log overs.
    6 days for Fox to reply with a canned response for me to check the sag.
    Chilling out
    sad. not super surprising for e-mail support, but sad.
    i really wish companies would state up front how long it'd take to get a response back.
    having a 'bot auto-reply with "we got it, but it could take 3-6 business days for someone to look at your mail" isn't really THAT difficult, is it?
    Reputation: eurospek's Avatar
    Quote Originally Posted by CraigH View Post
    Overall, still unimpressed with the CTD stuff?
    I have a 2012 Talas 34 FIT RLC and debating if I should ditch it completely for a new 2013 CTD Float 34 or just do the Float cartridge replacement at the end of the season on the Talas.
    The reviews I've been reading haven't been great (Bikeradar.com) and others completely the opposite of how stellar and finally getting full and plusher travel from the CTD (according to the guys @ Transition).
    konahonzo
    I liked how the fork worked yesterday, I rode both the bike & the fork hard, the same way I ride my VP-Free other than I was keeping the drops to around 2 feet until I get more time on the bike.
    That was only one ride though.
    Maybe the fork is sensitive to air pressure, rebound or it is just breaking in? The changes from Rides #1&2 to #3 was 10 psi and 6 clicks of rebound. I'm now running the suggest Fox set up.
    If people are still interested in how it goes with CTD, I can keep this thread updated.
    Please do.
    konahonzo
    Quote Originally Posted by eurospek View Post
    Maybe the fork is sensitive to air pressure, rebound or it is just breaking in? The changes from Rides #1&2 to #3 was 10 psi and 6 clicks of rebound. I'm now running the suggested Fox set up.
    Quote Originally Posted by bear View Post
    Santa Cruz usually responds in hours.
    WTB took a day.
    The Fox response didn't even link the owners manual/set up guide for the fork.
    I have no idea why they don't link the owners manual/set up guide from the sales tech info page for specific fork. It would also be nice if they included it with the fork instead of the 77 page shiny brochure with no info in it.
    Chilling out
    I also wish there was PDF form of the detailed manual, so I could put it in the PDF reader on my "overly complex and expensive computing device that also can make phone calls".
    Hmm. Maybe a project in there for me to waste time on.
    How it's going with my CTD fork on my Yeti SB95 you ask?
    I have over 100 miles of trail riding on it so far, half of that in on Sat/Sun on some truly excellent NE PA singletrack with some double-track connectors. Lots of climbing (over 6k feet total in the two days) with commensurate descending.
    Riding conditions varied from forest road to not-quite-buff singletrack to nowhere near buff singletrack to good traditional PA rock gardens going up, across, and down. I'd try to describe them but Team Dicky has done it so well when talking about his rides on the 2012 Trans-Sylvania Epic ( see comments on Rothrock in part 1 and RB Winter in part 2 ).
    My CTD fork has been, to me, superb(-). I don't have a bunch of late model Fox-based experience though so I can't compare it to previous generation. My fork came on my bike and appears to have the full poo-poo-platter (it's a 2013 CTD Float 29 with Kashima).
    The Minus comes from not quite getting full travel - the disclaimer being a) I have come within 5 mm or so and thus don't think there's an issue so much as I haven't hit it hard enough, and b) I am still playing with PSI to see where I want it. The "cockpit" setup on my bike is still undergoing tuning and that affects weighting of the fork in various conditions and thus fork setup.
    Climb mode definitely most-stiff and very suitable for extended gravel-grinding climbs, and while leaving it in Trail mode also works well enough in those conditions it is perceptibly stiffer in Climb mode than Trail-3 (1==lightest, 3==stiffest Trail mode). Coupled with the RP23 in "stiff" mode and it makes my bike climb roads very adroitly. Not QUITE as solid as the Reba XX locked-out on my hard-tail, and visibly more mobile - especially when standing-hammering - but feels good. Doesn't feel like it's holding me back.
    Trail mode is definitely suitable for overall use, as designed. I tend to use either setting 1 or 2, mostly 1, as even this does seem to cause the fork to sit a bit higher in the travel overall (vs Descend mode) while still be very active on the bumpy trail I ride. Setting 3 is NOT "like" Climb mode, but definitely in the direction of Climb mode.
    Descend mode feels very different to me than Trail mode 1. Much more fork dive on rear-only braking, very very active. I swear that in this mode the fork behavior really makes me think of my other FS bike ( Titus Super-Moto setup for DH/FR with 2010 Boxxer ) .... I bombed some of the chunky stuff in Bald Eagle forest (what Dickey talks about in the "RBWinter" stage) at velocity bordering on inappropriate (in my judgement) for someone not wearing body armor. The front end of my bike never felt like it was throwing me around, it was tracking where I asked it to go, and was riding high enough that when I hit a couple surprise log-overs they were adroitly handled.
    My previous trail bike is a Niner MCR-9, with 100mm stroke Reba XX on the front that I have tuned (oil and grease and maintenance) into what feels good for me. The Reba is good, but is significant steps behind the Fox. This I expect from a couple model year gap. The Niner is also way behind the Yeti in ride feel, the Yeti is much more "all my thing" - I'm happier on FS - just very picky on *which* suspension type.
    Also, I currently have the fork at the stock 120mm stroke and am thinking about pulling it apart tonight and removing the limiter to take it out to 140. That is probably going to happen, so long as I have enough appropriate fork oil to put it back together. That will further slacken the head on my Yeti by almost one degree. Gotta remember to put body army in the bike bag.
    I want to see reviews from the 140mm version
    Chilling out
    Quote Originally Posted by lavoiespeed3 View Post
    Mine's the 120/140 version, going 140 tonight, but won't get to ride it again until Wed.
    What are you wondering about specifically on the 140?
    because at 120mm you don't really test the full" Descend mode '' I think at 140mm you will be able to make a better '' All Mountain Fork Review ''
    Chilling out
    Curious - why not?
    FWIW, my fork is now in 140mm setting. Probably won't have significant downhill until the weekend (or Friday) but it'll see first action Wed evening. ;^)
    It's going to be interesting seeing how the ride changes on the bike with ~1d slacker HTA/STA and so forth.
    FWIW, the fork has the new SKF dust wipers. The foam rings were wet, but got more fluid. The lowers were well lubed and running perfectly clean so far (dang right - it better have been).
    Now, to almost completely re-start tuning the suspension balance on the new bike. ;^)
    Reputation: JammerNinerBoxx's Avatar
    I just ordered my Fox 34 talas 110/140 for my new build. Rip9 I'll keep those who are interested informed on what I think/feel.
    Reputation: Heretic Skeptic's Avatar
    Mar 2012
    So the CTD forks are capable of being adjusted from 120mm to 140mm? The good news keeps piling on.
    I'm not sure as mine is already 140mm. Just measured and I have a 154mm from top of dust seal to bottom of crown on the stanchion.
    Maybe Arthur can help you out???
    Chilling out
    Craig, I don't have a pic from before I pulled the spacer, but I remember measuring it when I got the bike and it was in high 120's mm wise.
    player hater
    5th ride - Bob city on the Climb mode. Unhappy.
    Moved from a 29er fit 120 to a 29er fit 120 CTD with the "medium" designation. The 2011 pretty much locks out when off. The CTD in climb is bobbing a good 2 to 3 inches - unless I kick up the pressure in the 110#s - Setting the correct sag has me in the 85-90# range.
    Anyone using the "firm" tuned fork and not having the massive bob?
    Fox says:
    NOTE: The fork may cycle a couple of times after you engage Climb mode. Once complete Climb mode is achieved, the fork may continue to move 3 - 5 mm. This is normal, and does not affect performance.
    Quote Originally Posted by bjunsveltie View Post
    The manual has 2 recommended pressures depending if you want XC or AM fork action.
    I haven't looked at how much the fork is moving when climbing but I can feel the difference between the Trail/medium & Climb mode.
    (This is on the 140 29er fork.)
    Mar 2011
    I have the 100mm .. am I able to make it 120mm?
    2014 Santa Cruz Tallboy LTc
    Trek Farley 8
    iDream Images
    Not sure how you change from decend to trail on the fly. At least with the old RP23 it was either on or off.
    Chilling out
    Fork has a top crown lever with three positions for Climb, Trail, & Descend which may be flipped to any position at any time.
    If the fork has Trail Adjust that is a secondary ring.
    Well don't know where to start with all of this, So here it's goes! First I want to say this is just my opinion. I've been riding Mountain Bikes since '97 and I've seen and done all the changes that come with the times. I remember having a 63mm Manitou spring loaded front fork on my Trek 8000 and thought I was the ****. And never complained once about small bump compliance or not traveling enough or not locked out. Sure I understand we have all of these options today. And we pay dearly for them.
    Now I might be alittle bias on the subject because every since I've bolted on my first fox fork I thought it was the cats meow. Now what has got me a little pissed off in this thread is people criticizing the CTD.Sure it's new, sure it's change, but what get me is people want to point and pull the trigger @ something just because it don't have what there used to. My guess is the people that are b****in about it would be the biggest beneficiaries of the CTD because they don't have a clue on what does what when it comes to setting up the old RLC anyways.
    MTBR Member
    Reputation: ncfisherman's Avatar
    Quote Originally Posted by JammerNinerBoxx View Post
    What gets me, is the folks stating that the CTD is oversimplified when compared to the RLC like it is a bad thing. The CTD has a wide range of compression adjustments that are more quickly/easily accessible than the RLC setup. The knobs are also improved, with three solid clicks for the CTD knob(and the trail adj knob), which makes it easy to adjust while rolling - because of this, I have been finding that I use the adjustments much more and am quickly able to get the fork set for particular sections of trail. One drawback for some people, will be the lack of a firm lockout, which is not adjustable with lockout force knob like on the previous RLC forks. For me, that is not an issue because I don't like a super firm lockout as it's not really usable on the trail.
    Currently owning a couple RLC's and also having a CTD float for a few weeks, it's becoming clear that I prefer the CTD setup - and I'm someone that knows how to dial in a fork the way I like and also do all my fork maintenance.
    I know it has the levers but I am guessing you will have a hard time picking trail while moving along on the trail. Seems like the old Talas which had 3 positions which they got ride of for 2 since the middle one was next to impossible to use while moving.
    Chilling out
    On relatively quiet trail I don't have an issue flipping D to T or back, but agreed that it's not something done while picking a line.
    Good bit is that it's not *that* bad if you're slow-picking a line in D mode...just a bit squorshier up front in that case, but not fatal.
    I am guessing when I get the new bike I will be running it in D mode all of the time. I am not worried about climbing.
    Quote Originally Posted by The Beater View Post
    I mostly leave it in the trail mode, if I see a serious decent coming up I can reach forward and down to flip id to decent mode. At the bottom I can flip it back to trail, I have only used the climb mode on gravel roads.
    In the media intro articles they showed a remote that you can put on your bar, I don't have one but it isn't a bad idea. Not sure what they cost though.
    You bragging?
    I'll see your '97 and raise you an '83.
    Chilling out
    If you're gonna do that, you gotta ask when you started regularly riding ANY bicycle mostly on dirt?
    On topic, kind of, holy cow but the Fox 34 Float 29 CTD is just craaaaaazy better than my old Rock Shox RS-1.
    Reputation: Whason's Avatar
    So I'm trying to figure out if I should upgrade to 2012 or 2013.
    I have currently a 2011 32 float 100 mm 9 mm qr open bath on my Lynskey hardtail.
    I got this great deal on xtr 15 mm thruaxle wheelset so now I'm looking to upgrade to 15mm thruaxle qr and I'm debating whether to buy the 2012 32 FLOAT 100 RLC FIT Fork for 640 off of huck and roll or wait until the 2013 with the CTD stuff. Is CTD worth the extra 200 bucks or so?
    "Chancho. When you are a man sometimes you wear stretchy pants... Its for fun..."
    CTD stuff is out already, no waiting. And I would go with the 2012 FIT RLC anyway.
    konahonzo
    Maybe 1970?
    Chilling out
    Maybe 1970?
    Me too.
    endoguy
    Reputation: endoguy's Avatar
    I just set up the fork using the apple app from fox. The app recommended ten psi less than what is recommended for my weight. The app is designed to determine psi and rebound rate bay analyzing the amount of sag when sitting on the bike. My question is what about the low speed compression knob? How does one determine how to set up low speed compression?
    Mar 2013
    Hello fellow Fox CTD owners. I just purchased a 2013 Transition Covert 26 with Fox's new 34x160mm CTD fork and matching CTD shock. In addition to wheels-on-the-ground trail and DH riding, I expect to be hitting a number of flowy jump lines on this bike. I am confused by the new CTD settings. On my other Fox suspension, for jump lines I would set my compression fully stiff to be able to pop off the jump lips with minimal travel absorbed by the suspension. With CTD, I would naturally assume that setting it the in Climb mode would provide for this stiff setup, but I have been told by my LBS that doing so may cause damage to the internal seals when I come down on the backside. Argghh! What to do? Ideally, I would have it stiff for the jump, and then flip a lever in mid-flight to soften it up for the landing - a janx fix at best. Anyone jumping with these CTD's that can provide some light on the subject?
    JDM
    JDM is offline
    Reputation: JDM's Avatar
    Putting your fork in 'T' mode is the like cranking up the LSC.
    Mar 2006
    Hello
    i just got my remedy 8 a few days ago..with drcv float 150mm. What puzzled me is..i cant get the setup right..i set the sag right for my weight but the travel drops to 140..then rode the bike..i put more air to get the 150 travel..then i cant get the sag right...pls help...
    Did any of you guys ever come up with settings that made you happy? I'm 225 lbs with gear and just can't get this fork to feel right on my Tallboy LTc.
    Just sent mine back because it seemed like the rebound adjust knob did nothing. Did 4 rides and it never felt good. Climbing was great, but the descents were unpredictable and had 2 bad lowside washouts. I have the same fork in the RLC (34 Talas 29er 140-110). The old model for me (so far) is waaay better. I hope they send back a fork that "works". In other words, I hope they don't send it back and say it is fine and that is how it is supposed to be. If so I have a fork for sale.
    ^ Maybe request an RLC damper instead of the CTD if they are fixin' under warranty.
    konahonzo
    JDM
    JDM is offline
    I have a few rides on my '13 CTD fork now. I'm finding that it works really well.
    The rebound adjustment resolution is fine enough that a single click is nearly imperceptible, but the range is plenty wide to cover from too fast to too slow. It also seems easy to set it where it won't buck you off, but still avoid packing up. I'm guessing that this is thanks to the shimmed HSR circuit.
    The low speed compression range given in trail mode seems to give some nice control with out being too harsh. That said, I usually run the fork in descend mode or the lightest trail mode, unless I"m on really smooth trails (which we don't have many of in NH). I like a fork to be really active on the bumps. I also like a fork to compress (dive) in braking to help transfer weight forward for more traction in cornering (and a slightly steeper HTA). When I want to brake hard without compressing the fork, I just shift my weight back.
    I haven't really tried the climb mode and doubt I"ll use it much. I do most of my climbing in the saddle and usually want my fork to stay active on climbs. When I need to get out of the saddle I just do my best to stay smooth and live with what ever I get for bob.
    The combination of HSC and spring rate seem to be giving me appropriate travel over a range of bump sizes. I seem to use nearly all the travel at some point on most rides but it never seems to be wallowing.
    Quote Originally Posted by JDM View Post
    How much do you weigh and what pressure are you running?
    JDM
    JDM is offline
    My fork is the 140mm 29er model. I weigh 195#.
    I don't remember the pressure. I set it to about 30% sag at first. I brought my shock pump on the first ride and ended up adding a bit more air on the side of the trail. Hillharman, you might want to adjust the amount of float fluid on top of the air chamber to tune the progressiveness of the fork. I'm guessing you would want to start by adding a few cc of float fluid (or similar) to the top of the air chamber to make the air spring more progressive.
    I did drain the bath oil in the lowers and refill when I first got the fork, before mounting it. I measured bout 15 cc out of each leg, but didn't wait around all day for it to drain out. I'm sure it had a bit more than I measured, but it certainly didn't have the 30 cc that the tech manual called out. I also put a little buzzy's honey slick on on the seals before reassembly.
    I'll throw in my review to balance what I've read on this thread so far:
    I put one ride in with my 2013 CTD 34 150mm Float and sent it straight back to Fox for a damper upgrade (will probably boost the progression with Float oil in the air chamber when I get it back). Spent the entire ride trying to find a sweet spot and never got close. Basically, to keep the fork from diving horribly in every hard turn I had to ride it WAY oversprung and only descend in Trail mode with the Trail damping turned all the way up. Of course the fork felt like shit, but at least I was able to lean the bike at speed. Bringing the settings down to the point where bump sensitivity was decent pretty much guaranteed I'd bottom out when going fast and changing direction.
    To be honest, when I bought the fork I suspected all the negative press was simply a few grouchy media reviews and a whole bunch of lemmings who piled on because everyone loves to hate Fox. But no, the tune on this fork really is quite awful, IMO.
    Reputation: xokokx's Avatar
    will like to ask what's the psi u guys using ?
    im 70kg and using 60psi not able to get the sag required.
    do u guys recommend to reduce the psi ?
    im using 2013 34 160 talas
    Quote Originally Posted by gaba View Post
    How did you notice the rebound not working? I think mine has the same issue. Cant tell any difference in speed at all.
Members who have read this thread: 4
