    2012/13 Fox 36 float - Strange noise?
    Hi guys, Iv recently converted my fox 36 talas to float and now they are making a strange clunking noise when compressed, it sound very much like this
    Its almost like the negative spring assembly is knocking against the inside of the stanchion?
    I can also extend the forks by ~5mm by pushing on the crown with no weight on the front wheel and this produces a metallic clunk which is something the talas cartridge doesn't do?
    Iv put the talas cartridge back in and now the forks are silent again....
    Dec 2009
    did they provide a negative spring plate with the kit.long shot, but it may be different between float and talas. from memory the 2012 float negative plate is a hat section shape. the 2013 is a flat plate.
    Quote Originally Posted by gvs_nz View Post
    Yeh they did provide a new negative spring plate, looks like this which then sits nicely on the red travel spacer
    2012/13 Fox 36 float - Strange noise?-2013_travel_adj_sp_update_02.gif
    Iv had the forks in bits again over the weekend, it still sounds like its topping out after certain hits...but not all?! Also Iv been told the spring can be noisy as it hits the plastic assembly and heat shrink around the spring would reduce the noise?
  1. Strange knocking noise/play from shock mounts
    By ButchSchlong in forum Nicolai
    Last Post: 06-13-2014, 05:41 AM
  2. RIP 9 with an Anglest - Having strange noise issues
    By austin_bike in forum Niner Bikes
    Last Post: 04-10-2014, 06:18 PM
  3. Fox 32 CTD fork strange noise!
    By Paris Galanis in forum Trek
    Last Post: 11-03-2013, 11:07 PM
  4. Strange Clicking Noise
    By lostbackpacker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2013, 05:43 PM
  5. strange clicking noise
    By hozman67 in forum Bike and Frame discussion
    Last Post: 10-16-2012, 09:56 AM
