    Feb 2005
    2011 Lyrik RC2DH
    Can this fork be spaced down to 160mm? I know the solo air can but wondering about this one.
    If your referring to the coil version then yes. They don't make a 160 spring so it will have a little more preload on it or you can heat and lower the spring a little. I went from a kashima 180 float to a 160mm rc2dh coil lyrik and it's 100x better.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    RC2DH is a solo-air with a different damper. travel adjust is the same.
    Feb 2005
    Here is the one I'm referring to. I thought in for 2011 they made an RC2DH that was coil at 170mm from the factory.
    Lyrik RC2 DH | SRAM
