Results 1 to 2 of 2
    2011 Fox Vanilla 36 170 R....covert to 160mm? Can it be done reliably?
    I know its not supposed to be possible according to Fox, but hoping someone out there has tried it and succeeded. Originally I was gonna pick up a Nomad frame, which the 170mm Fork would have been fine for, but some things don't go according to plan. Now looking at a Butcher but 170 is more that what is designed for and voids warranty. Any suggestions, or should I just sell the thing and purchase a 160mm.
    www.derbyrims.com
    Reputation: derby's Avatar
    Haven't done it. However, you should be able to stack a 10mm washer above or below the top-out spring. A plastic washer would be lightest. If you can't find a washer at the size needed, cutting a slice of plastic pipe having the diameter of the negative spring could work well.
    Stacking a washer with the negative spring will both lower the fork and reduce travel. Stacking washers below the bottomout bumpers will only reduce travel without lowering the overall fork's crown height.
  1. 2011 Fox Float 36 RC2/FIT 160mm
    By rickymheim in forum General Discussion
    Last Post: 07-31-2011, 08:33 PM
  2. 2011 covert headset confusion!
    By hugh_b in forum Transition Bikes
    Last Post: 06-08-2011, 01:17 AM
  3. Users of Fox 36 160mm Van Rc2 fit 2011
    By Stefan Nielsen in forum Shocks and Suspension
    Last Post: 02-02-2011, 04:35 AM
  4. 2011 36 TALAS...why 120 to 160mm?
    By jubilee in forum Shocks and Suspension
    Last Post: 08-13-2010, 04:35 PM
