FAT BIKES
WINTER APPAREL
TRAINERS
Page 12 of 12 FirstFirst ... 2 8 9 10 11 12
Results 276 to 289 of 289
  1. #276
    Now, THAT'S gonna hurt!
    Reputation: Oh My Sack!'s Avatar
    Have you guys done the steerer tube from the bottom of the Crown, too. I did the stanchions (upside down) where they meet the Crown but I'm still experiencing the creeking noise. I used the Loctite 290 after using their Klean and Prime activator.
  2. #277
    Sep 2013
    I did the steerer tube from the bottom of the crown as well.
  3. #278
    Hmmm...ok. So, I applied a mix of 290 and 609 to the bottom of the crown/ stanchion interface, twice, and the steerer/crown once. Let dry for 24, then set upright for another 24. No luck. Should I do the top of the stanchion interface, and the steerer? If I do the stanchions, won't that lock the top caps?
  4. #279
    moaaar shimz
    Reputation: tacubaya's Avatar
    Did you apply first the 290, let 24 hour cure and then apply the 609 and cure for 24 hours?
    Only apply on the stanchion/crown interface (and on the steerer/crown if you are 100% sure the creak comes from there), don't apply it anywhere else.
  5. #280
    I still can't get rid of my creak. It's definitely coming from the fork- swapping to a rigid fork eliminates the noise, and I can just barely get the fork to do it in my hands.
    I mixed the two, then applied and allowed to cure for 24hr upside down, 24hr rightside up. I can see a thin ring of stuff in the stanchion/crown joint, but not under the steerer. I can try the top interface of the steerer, and remove the crown race...
  6. #281
    moaaar shimz
    Why did you mix them? That defeats the purpose of each loctite.
  7. #282
    Quote Originally Posted by tacubaya View Post
    My thought as well. Not seeing the benefit.
  8. #283
    I guess I figured lowered viscosity with higher binding strength? So that it would wick into the crevices but still be strong enough to not give up over time? Because some people said that 290 didn't work, but 609 wasn't thin enough to penetrate?
  9. #284
    Aug 2014
    Thank you all for this thread. I have bought a used Specialized stumpjumper carbon and have the same annoying problem with my FOX 32 fork. I tried the oil/ teflon and let it the fork stand uppside down overnigth, but that did not work. I wrote FOX services Germany, but they has not answerd yet. I guess the next step is to trie tho degrease the thing and trie the locktite solution, but there is also no garantee for succes. I Think it depnds if the fluid really can creep in between. Stupid that locktite write on their website they have the absolute solution to make pressfit fittings ultimatively stable when lockite is applied before pressing the fork togehter. Why Doesn't FOX use Locktite right from the start?
  10. #285
    Everybody here's the solution for creaky steerer tube and stanchions. An exclusive process invented by the Bicycle Jesus himself.
    Stanchion Repress | Blue Liquid Labs
    Check out the suspension services page as well.
    Suspension Department | Blue Liquid Labs
  11. #286
    Dec 2010
    Thanks for that Oliver - I've parked your link away in case I run into this (I didn't even know this could be done).
  12. #287
    moaaar shimz
    Quote Originally Posted by olivermajewski View Post
    Oliver.
    Many manufacturers have tried using Loctite during CSU assembly (and some still do) to eliminate the creaking, but it eventually comes back. I personally think it's one the best solutions we have, yet it remains an unsolved problem.
    Btw, you mention you are the only one in the world doing that, but I know a few guys across the pond doing that and more, one technician even sends out wore out stanchions for centerless griding/honing and re-anodizing.
  13. #288
    Oliver.
    That's incredible. Do you have the names or websites of the guys that hone and re-anodize stanchions? Also, do you have the names of the guys who are repressing steerer tubes and stanchions? Is the amount they charge for honing and reanodizing less than brand new CSU's?
    Regarding longevity, I rode the creakiest fork I've ever heard for about 8 years. I pressed everything out and pressed it back in with loctite 609 and I've been riding creak free for 3 years now. 3 years is pretty good I think. Longer than cables can stay in tune. Longer than seals can last.
    I've pressed apart many forks now from many different brands and only one has ever had any residue of some retaining compound but I know exactly how loctite brand 609 looks when new and how it looks when old. I know exactly the color and I know exactly how it feels between my fingernails when it crumbles away. The stuff I've seen this manufacturer use didnt feel at all like loctite 609 retaining compound, it had to be something else.
  14. #289
    X Fusion Sweep - Creek
    I know this thread is ancient but its been a great source of information. I suspected i was getting a creek from the crown/steerer junction, thankfully this was not the case.
    I took of the forks and seen paint on the crown race. This was the cause of the creek, paint from the forks bonding to the aluminum c/race.
    I removed the paint with a blade, put a little grease between the c/r and the forks and now, no more creek.
    I faced the fork by putting a headset on(spaced it with h/set spacers) and clamping it in the work stand horizontal, then i was able to turn the forks and hold a blade against the crown. Just turned away to take it down to the metal. Came out surprisingly well. I can image a facing tool for this one job would be expensive.2011 fox forks creaking/cracking noise-gopr0297.jpg
    Attached Thumbnails Attached Thumbnails 2011 fox forks creaking/cracking noise-gopr0294.jpg
Follow MTBR on Facebook
