    2011 Fox 32 Float 29 RLC FIT Fork sanction play
    The other day I noticed a slight noise coming from the fork area while rocking my bike back and forth while the front brake was engaged. It almost feels like there is play in the drive side sanction tube? BTW...this is on my Tallboy carbon. One other thing, my Highball carbon has the same fork but in a 2012 and has this similar noise but less noticeable. It isn't bad but it just doesn't seem normal for the price I paid for these forks.
    To note, I just serviced the Dust Wiper/Seal kit and torqued everything back to spec and the same feeling/noise is still present.
    Any suggestion would be appreciated.
    MTBR Member
    Reputation: ncfisherman's Avatar
    Send the sloppy fork in for warranty - Fox will replace the bushings or lowers. I had to send one in earlier this year for the same issue.
    Fox might not cover the fork on the Highball. I have a new Float 150 CTD that also has a slight amount of knocking, but I'm not sure it's enough for Fox to be willing to do anything about it. I'm going to continue to ride my fork and address it if the problem becomes worse.
    Reputation: kendal's Avatar
    Sorry to hear the bushing problem, but dont feel bad seems to happen.
    FOX 32 FLOAT 29 100 FIT RLC, movement and clunking.. WTF?
    After 3 times back to Fox and expensive shipping they finally replaced mine due to lots of raising He*l. Just be sure to keep the assigned numbers they give you when you send it in. If the bike shop sends it in be sure and get it from them.
    2011 Yeti Big Top
    2012 Santa Cruz Tallboy
    1991 Cannondale m700
    Feb 2012
    Yeh same problem with mine. At first I thought it was my headset but it seems my fork toast!!
