2010 Totem Coil MiCo DH Oil levels?
I have broken open the above fork twice to change the lube oil. I rebuilt a friend's Totem solo air and was amazed at the difference changing the compression dampening oil made so I decided to change mine out. On the SRAMTECH youtube channel, the vid on MiCo rebuild states 137ml of oil for the Totem. I drained mine out and there was 200 ml. The fork has always felt pretty firm ( I like it that way). I couldnt find anything current on the 2010 DH forks, does anyone know if they use more oil? I put 140 ml of Maxima 7w back in there and the fork feels much more progressive. Is this a case of some taiwanese worked just dumping oil in the leg?
Update
Called SRAM this morning and they told me there is supposed to be 203 ml in the MiCo DH damper for the 2010 fork. It would be nice if they could get there website updated with specs on the forks as they are released.
- You may not post replies
- You may not edit your posts
Forum Rules
