Results 1 to 2 of 2
    Reputation: chris68's Avatar
    2010 Fox Float RP2 Oil Leak
    I have a 2010 Fox Float RP2 that seems to be leaking from the rebound/propedal knob. Is this bad? Also would the Fox Shock Replacement Seal kit fix this issue?
    moaaar shimz
    Reputation: tacubaya's Avatar
    Yes it is bad and no, you can't fix it with an air sleeve rebuild... it requires a full rebuild. Time to send it to Fox/Suspension Experts/PUSH
