Results 1 to 2 of 2
    2008 (?) Lyrik Mission Control problem.
    Last night I decided to tackle a 2008 (I believe) era Lyrik 2-step with mission control. It's symptoms were a small (2-3mm) amount of undamped travel in the start of the stroke, and the 2 step was blown.
    I bought an o-ring/seal kit and all the oil I needed, dismantled the fork, rebuilt the 2 step side (So simple to do), and then set to work on the Mission control.
    I had some problems.
    Problem 1, the M3 set screw in the HSC cap was stripped, and hard to get out.
    Problem 2, the oil volumes were listed as 193mL, and the fork could only take about 170 before overflowing. I then found the listing that it takes 112, and used that value.
    Put everything together, after cleaning, regreasing and changing suspect o-rings, and everything works as it should. 2 step functions well (I'm assuming that when you install the top cap, you open the bleed screw and let excess oil out, which will give you the right oil volume).
    Problem 3, the small amount of undamped travel is still there. It feels like there should be more oil in the damper or something, and the LSC knob isn't turning or doing anything really. Lockout works fine after the 2-3mm. It's topping out because of the lack of damping.
    Any ideas?
    Reputation: mullen119's Avatar
    I believe the 2-3mm is normal on Rock Shox air forks.
    The 193ml is for 2010+ lyriks, the 112ml is correct for the previous models.
    You might need to give some extra force to break the LSC loose. I have that problem when I service mine as well. It seems to get stuck in the fully open position. I use channel locks to grip it and spin it. Not too hard incase there is another problem, but it has always popped loose pretty easily for me.
  1. Rockshox Lyrik Mission Control DH
    By Cyphereza in forum Shocks and Suspension
    Last Post: 06-19-2013, 05:36 PM
  2. Lyrik Mission Control problems
    By Arryl in forum Shocks and Suspension
    Last Post: 01-24-2013, 12:27 AM
  3. Lyrik Mission Control Mod?
    By mullen119 in forum Shocks and Suspension
    Last Post: 12-07-2011, 12:24 AM
  4. Mission Control Lyrik doesnt feel right...
    By Cata1yst in forum Shocks and Suspension
    Last Post: 12-01-2011, 10:26 PM
  5. 08 RS Lyrik Mission Control.
    By Falling in forum Shocks and Suspension
    Last Post: 01-30-2011, 02:08 PM
